I am trying to install katello but it is failing with the following error:
# foreman-installer --scenario katello
Systemd start for httpd failed!
journalctl log for httpd:
-- Logs begin at Wed 2018-01-03 18:10:44 EST, end at Wed 2018-03-14 14:33:18 EDT. --
Mar 14 14:33:18 server systemd[1]: Starting The Apache HTTP Server...
Mar 14 14:33:18 server httpd[53227]: httpd: Syntax error on line 38 of /etc/httpd/conf/httpf: Syntax error on line 1 of /etc/httpd/conf.modules.d/wsgi.load: Cannot load modules/mod_wsgi.so server: /etc/httpd/modules/mod_wsgi.so: cannot open shared object file: No such file or directory
Mar 14 14:33:18 server systemd[1]: httpd.service: main process exited, code=exited, status=LURE
Mar 14 14:33:18 server kill[53229]: kill: cannot find process ""
Mar 14 14:33:18 server systemd[1]: httpd.service: control process exited, code=exited statu
Mar 14 14:33:18 server systemd[1]: Failed to start The Apache HTTP Server.
Mar 14 14:33:18 server systemd[1]: Unit httpd.service entered failed state.
Mar 14 14:33:18 server systemd[1]: httpd.service failed.
/opt/puppetlabs/puppet/lib/ruby/vendor_ruby/puppet/provider/service/systemd.rb:167:in `rescue in s
/opt/puppetlabs/puppet/lib/ruby/vendor_ruby/puppet/provider/service/systemd.rb:164:in `start'
/opt/puppetlabs/puppet/lib/ruby/vendor_ruby/puppet/type/service.rb:103:in `block (3 levels) in <moPuppet>'
/opt/puppetlabs/puppet/lib/ruby/vendor_ruby/puppet/property.rb:487:in `set'
/opt/puppetlabs/puppet/lib/ruby/vendor_ruby/puppet/property.rb:561:in `sync'
/opt/puppetlabs/puppet/lib/ruby/vendor_ruby/puppet/type/service.rb:114:in `sync'
/opt/puppetlabs/puppet/lib/ruby/vendor_ruby/puppet/transaction/resource_harness.rb:236:in `sync'
/opt/puppetlabs/puppet/lib/ruby/vendor_ruby/puppet/transaction/resource_harness.rb:134:in `sync_ifed'
/opt/puppetlabs/puppet/lib/ruby/vendor_ruby/puppet/transaction/resource_harness.rb:80:in `perform_es'
/opt/puppetlabs/puppet/lib/ruby/vendor_ruby/puppet/transaction/resource_harness.rb:21:in `evaluate
/opt/puppetlabs/puppet/lib/ruby/vendor_ruby/puppet/transaction.rb:233:in `apply'
/opt/puppetlabs/puppet/lib/ruby/vendor_ruby/puppet/transaction.rb:249:in `eval_resource'
/opt/puppetlabs/puppet/lib/ruby/vendor_ruby/puppet/transaction.rb:163:in `call'
/opt/puppetlabs/puppet/lib/ruby/vendor_ruby/puppet/transaction.rb:163:in `block (2 levels) in eval
/opt/puppetlabs/puppet/lib/ruby/vendor_ruby/puppet/util.rb:507:in `block in thinmark'
/opt/puppetlabs/puppet/lib/ruby/2.1.0/benchmark.rb:294:in `realtime'
/opt/puppetlabs/puppet/lib/ruby/vendor_ruby/puppet/util.rb:506:in `thinmark'
/opt/puppetlabs/puppet/lib/ruby/vendor_ruby/puppet/transaction.rb:163:in `block in evaluate'
/opt/puppetlabs/puppet/lib/ruby/vendor_ruby/puppet/graph/relationship_graph.rb:118:in `traverse'
/opt/puppetlabs/puppet/lib/ruby/vendor_ruby/puppet/transaction.rb:154:in `evaluate'
/usr/share/gems/gems/kafo-2.0.0/modules/kafo_configure/lib/puppet/parser/functions/add_progress.rbn `evaluate_with_trigger'
/opt/puppetlabs/puppet/lib/ruby/vendor_ruby/puppet/resource/catalog.rb:222:in `block in apply'
/opt/puppetlabs/puppet/lib/ruby/vendor_ruby/puppet/util/log.rb:155:in `with_destination'
/opt/puppetlabs/puppet/lib/ruby/vendor_ruby/puppet/transaction/report.rb:146:in `as_logging_destin'
/opt/puppetlabs/puppet/lib/ruby/vendor_ruby/puppet/resource/catalog.rb:221:in `apply'
/opt/puppetlabs/puppet/lib/ruby/vendor_ruby/puppet/configurer.rb:171:in `block in apply_catalog'
/opt/puppetlabs/puppet/lib/ruby/vendor_ruby/puppet/util.rb:224:in `block in benchmark'
/opt/puppetlabs/puppet/lib/ruby/vendor_ruby/puppet/util.rb:223:in `benchmark'
/opt/puppetlabs/puppet/lib/ruby/vendor_ruby/puppet/configurer.rb:170:in `apply_catalog'
/opt/puppetlabs/puppet/lib/ruby/vendor_ruby/puppet/configurer.rb:343:in `run_internal'
/opt/puppetlabs/puppet/lib/ruby/vendor_ruby/puppet/configurer.rb:221:in `block in run'
/opt/puppetlabs/puppet/lib/ruby/vendor_ruby/puppet/context.rb:65:in `override'
/opt/puppetlabs/puppet/lib/ruby/vendor_ruby/puppet.rb:306:in `override'
/opt/puppetlabs/puppet/lib/ruby/vendor_ruby/puppet/configurer.rb:195:in `run'
/opt/puppetlabs/puppet/lib/ruby/vendor_ruby/puppet/application/apply.rb:350:in `apply_catalog'
/opt/puppetlabs/puppet/lib/ruby/vendor_ruby/puppet/application/apply.rb:274:in `block in main'
/opt/puppetlabs/puppet/lib/ruby/vendor_ruby/puppet/application/apply.rb:225:in `main'
/opt/puppetlabs/puppet/lib/ruby/vendor_ruby/puppet/application/apply.rb:170:in `run_command'
/opt/puppetlabs/puppet/lib/ruby/vendor_ruby/puppet/application.rb:375:in `block in run'
/opt/puppetlabs/puppet/lib/ruby/vendor_ruby/puppet/util.rb:662:in `exit_on_fail'
/opt/puppetlabs/puppet/lib/ruby/vendor_ruby/puppet/application.rb:375:in `run'
/opt/puppetlabs/puppet/lib/ruby/vendor_ruby/puppet/util/command_line.rb:132:in `run'
/opt/puppetlabs/puppet/lib/ruby/vendor_ruby/puppet/util/command_line.rb:72:in `execute'
/opt/puppetlabs/puppet/bin/puppet:5:in `<main>'
/Stage[main]/Apache::Service/Service[httpd]/ensure: change from stopped to running failed: Systemrt for httpd failed!
/Stage[main]/Foreman_proxy::Register/Foreman_smartproxy[server.org]: Could not eva: Exception Connection refused - connect(2) for "server.org" port 443 in get reques https://server.org/api/v2/smart_proxies?search=name=%22server.org%2
/usr/share/foreman-installer/modules/foreman/lib/puppet/provider/foreman_resource/rest_v3.rb:89:incue in request'
/usr/share/foreman-installer/modules/foreman/lib/puppet/provider/foreman_resource/rest_v3.rb:71:inuest'
/usr/share/foreman-installer/modules/foreman/lib/puppet/provider/foreman_smartproxy/rest_v3.rb:6:ioxy'
/usr/share/foreman-installer/modules/foreman/lib/puppet/provider/foreman_smartproxy/rest_v3.rb:13:d'
/usr/share/foreman-installer/modules/foreman/lib/puppet/provider/foreman_smartproxy/rest_v3.rb:17:xists?'
/opt/puppetlabs/puppet/lib/ruby/vendor_ruby/puppet/property/ensure.rb:81:in `retrieve'
/opt/puppetlabs/puppet/lib/ruby/vendor_ruby/puppet/type.rb:1070:in `retrieve'
/opt/puppetlabs/puppet/lib/ruby/vendor_ruby/puppet/type.rb:1098:in `retrieve_resource'
/opt/puppetlabs/puppet/lib/ruby/vendor_ruby/puppet/transaction/resource_harness.rb:300:in `from_ree'
/opt/puppetlabs/puppet/lib/ruby/vendor_ruby/puppet/transaction/resource_harness.rb:20:in `evaluate
Wrapped exception:
/opt/puppetlabs/puppet/lib/ruby/2.1.0/net/http.rb:879:in `initialize'
/opt/puppetlabs/puppet/lib/ruby/2.1.0/net/http.rb:879:in `open'
/opt/puppetlabs/puppet/lib/ruby/2.1.0/net/http.rb:879:in `block in connect'
/opt/puppetlabs/puppet/lib/ruby/2.1.0/timeout.rb:90:in `block in timeout'
/opt/puppetlabs/puppet/lib/ruby/2.1.0/timeout.rb:100:in `call'
/opt/puppetlabs/puppet/lib/ruby/2.1.0/timeout.rb:100:in `timeout'
/opt/puppetlabs/puppet/lib/ruby/2.1.0/net/http.rb:878:in `connect'
/opt/puppetlabs/puppet/lib/ruby/2.1.0/net/http.rb:863:in `do_start'
/opt/puppetlabs/puppet/lib/ruby/2.1.0/net/http.rb:852:in `start'
/opt/puppetlabs/puppet/lib/ruby/2.1.0/net/http.rb:1375:in `request'
/opt/puppetlabs/puppet/lib/ruby/gems/2.1.0/gems/oauth-0.5.1/lib/oauth/consumer.rb:161:in `request'
/usr/share/foreman-installer/modules/foreman/lib/puppet/provider/foreman_resource/rest_v3.rb:76:inuest'
Installing Done [100%] [................
The httpd related error message shows the wsgi files:
# cat /etc/httpd/conf.modules.d/wsgi.load
LoadModule wsgi_module modules/mod_wsgi.so
# cat /etc/httpd/conf.modules.d/wsgi.conf
# The WSGI Apache module configuration file is being
# managed by Puppet an changes will be overwritten.
<IfModule mod_wsgi.c>
WSGISocketPrefix /var/run/wsgi
</IfModule>
I have of course changed the hostname.
Install katello properly.
foreman 1.15
katello-3.14
