katello-nightly-rpm-pipeline 1067 failed
https://ci.theforeman.org/job/katello-nightly-rpm-pipeline/1067/
foreman-pipeline-katello-nightly-centos8-install (failed) (remote job)
foreman-pipeline-katello-nightly-centos8-stream-install (failed) (remote job)
foreman-pipeline-katello-nightly-centos8-upgrade (failed) (remote job)
foreman-pipeline-katello-nightly-centos7-install (passed) (remote job)
foreman-pipeline-katello-nightly-centos7-upgrade (failed) (remote job)
EL8 is failing with
[ERROR ] [configure] - nothing provides facter needed by rubygem-foreman_maintain-1:0.8.12-2.el8.noarch
Seems something broke with the changes yesterday.
CC @ehelms @pcreech @upadhyeammit
Looks like we have two options:
  1. “revert” the change and let foreman-maintain RPM assume that facter is available due to assumed presence of puppet-agent since it dropped the provides on facter with Puppet 7
  2. Require rubygem-facter and rely on facter from a dedicated RPM
  1. replace the use of facter with something simpler, like reading /etc/os-release.
