jenkins
1
ekohl
2
I expected this to fail on openscap (we should have fixed Ansible) but this is new:
[2022-02-24T18:14:22.727Z] TASK [update_os_packages : RedHat | Update packages] ***************************
[2022-02-24T18:14:22.727Z] e[0;31mfatal: [pipe-up-katello-nightly-centos8-stream]: FAILED! => changed=false e[0m
[2022-02-24T18:14:22.727Z] e[0;31m failures: []e[0m
[2022-02-24T18:14:22.727Z] e[0;31m msg: |-e[0m
[2022-02-24T18:14:22.727Z] e[0;31m Depsolve Error occured:e[0m
[2022-02-24T18:14:22.727Z] e[0;31m Problem: package python38-createrepo_c-0.17.7-3.2.el8.x86_64 requires createrepo_c-libs = 0.17.7-3.2.el8, but none of the providers can be installede[0m
[2022-02-24T18:14:22.727Z] e[0;31m - cannot install both createrepo_c-libs-0.17.7-4.el8.x86_64 and createrepo_c-libs-0.17.7-3.2.el8.x86_64e[0m
[2022-02-24T18:14:22.727Z] e[0;31m - cannot install both createrepo_c-libs-0.17.7-3.2.el8.x86_64 and createrepo_c-libs-0.17.7-4.el8.x86_64e[0m
[2022-02-24T18:14:22.727Z] e[0;31m - cannot install the best update candidate for package python38-createrepo_c-0.17.7-3.2.el8.x86_64e[0m
[2022-02-24T18:14:22.727Z] e[0;31m - cannot install the best update candidate for package createrepo_c-libs-0.17.7-3.2.el8.x86_64e[0m
[2022-02-24T18:14:22.727Z] e[0;31m rc: 1e[0m
[2022-02-24T18:14:22.727Z] e[0;31m results: []e[0m
system
Closed
3
