katello-nightly-rpm-pipeline 1369 failed
https://ci.theforeman.org/job/katello-nightly-rpm-pipeline/1369/
foreman-pipeline-katello-nightly-centos8-stream-upgrade (failed) (remote job)
foreman-pipeline-katello-nightly-almalinux8-install (failed) (remote job)
foreman-pipeline-katello-nightly-centos8-stream-install (failed) (remote job)
foreman-pipeline-katello-nightly-almalinux8-upgrade (failed) (remote job)
I see failures which mention Simple Content access. Could anyone from @katello take a look? I’m not sure if this is a recent change in Katello, subscription-manager or something else.
The “SCA orgs can’t attach subs” check has been there for a while: https://github.com/Katello/katello/pull/8746
Wonder why it started happening now.
Aha!
There is a new candlepin in nightly (candlepin-4.2.3-1.el8 | Build Info | koji) which has the following in the changelog:
4.2.1-1
- ENT-3756: Implementation of SCA-by-default for newly created Owners
I guess that’s it?
Yes, that’s it. The new Candlepin build is going to require some dev effort to unbreak things around SCA because its behavior has changed in significant ways:
  • content access mode is now attached to the org, not the consumer (manifest)
  • Toggling SCA should not reach out to upstream Candlepin anymore
  • new orgs will now default to SCA, so we need to make Katello respect that even when a manifest is not imported
etc.
We need to make all the changes above. @cintrix84 & Candlepin folks can help if you need more details…
Are there issues tracking this? Can we unbreak the pipeline in the short term?
Should we just untag that candlepin build for the moment? Until Katello can handle it?
