katello-nightly-rpm-pipeline 139 failed
https://ci.theforeman.org/job/katello-nightly-rpm-pipeline/139/
foreman-katello-nightly-test (passed)
TASK [forklift : Write box file] ***********************************************
fatal: [localhost]: FAILED! =>
  msg: |-
    The task includes an option with an undefined variable. The error was: 'forklift_proxy_name' is undefined
    The error appears to be in '/root/forklift/roles/forklift/tasks/up.yml': line 2, column 3, but may
    be elsewhere in the file depending on the exact syntax problem.
    The offending line appears to be:
    - name: 'Write box file'
      ^ here
@ekohl - is this also related to the refactoring from last week?
Yes, I should test my Friday afternoon fixes properly:
