katello-nightly-rpm-pipeline 1596 failed
https://ci.theforeman.org/job/katello-nightly-rpm-pipeline/1596/
This seems to fail in the sync-plans phase, which seems to be fallout from Fixes #36024 - ignore already deleted sync plans by sbernhard · Pull Request #681 · theforeman/foreman_maintain · GitHub
cc @Bernhard_Suttner @ehelms
From the log:
I, [2023-02-22 23:50:44+0000 #63672]  INFO -- : --- Execution step 're-enable sync plans' [sync-plans-enable] started ---
D, [2023-02-22 23:50:44+0000 #63672] DEBUG -- : Running command PGPASSWORD='[FILTERED]' psql -h localhost  -p 5432 -U foreman -d foreman with stdin "SELECT 1 as ping"
D, [2023-02-22 23:50:44+0000 #63672] DEBUG -- : output of the command:
 ping
    1
(1 row)
D, [2023-02-22 23:50:44+0000 #63672] DEBUG -- : Running command PGPASSWORD='[FILTERED]' psql -h localhost  -p 5432 -U foreman -d foreman with stdin "COPY (      SELECT id FROM katello_sync_plans WHERE id IN ()\n) TO STDOUT WITH CSV HEADER"
 ERROR:  syntax error at or near ")"
LINE 1: COPY (      SELECT id FROM katello_sync_plans WHERE id IN ()
E, [2023-02-22 23:50:44+0000 #63672] ERROR -- : Illegal quoting in line 1. (CSV::MalformedCSVError)
I think the following should fix it:
diff --git definitions/features/sync_plans.rb definitions/features/sync_plans.rb
index 1484fd1..318a730 100644
--- definitions/features/sync_plans.rb
+++ definitions/features/sync_plans.rb
@@ -34,6 +34,8 @@ class Features::SyncPlans < ForemanMaintain::Feature
   end
   def validate_sync_plan_ids(ids)
+    return [] if ids.empty?
     ids_condition = ids.map { |id| "'#{id}'" }.join(',')
     query = <<-SQL
       SELECT id FROM katello_sync_plans WHERE id IN (#{ids_condition})
It does, so I posted Refs #36024 - don't fail on empty sync plan list by evgeni · Pull Request #687 · theforeman/foreman_maintain · GitHub
