https://ci.theforeman.org/job/katello-nightly-rpm-pipeline/1631/
Looks like the server returned an internal server error while loading autocomplete. I can’t find a log entry for the HTTP 500, but I do see:
2023-03-28T23:27:29 [F|app|141fd918]
141fd918 | TypeError (nil can't be coerced into Integer):
141fd918 |
141fd918 | lib/foreman/middleware/logging_context_session.rb:22:in `call'
141fd918 | lib/foreman/middleware/logging_context_request.rb:11:in `call'
141fd918 | katello (4.9.0.pre.master) lib/katello/prevent_json_parsing.rb:12:in `call'
Given it’s F(atal), I think it failed to even reach the controller. It already stopped processing in the middleware, but I don’t really see where it would fail.
Yeah, I was having trouble figuring out where this is coming from too. In the logs I saw (from the older failure) it was right after it loaded manifest_history
, but you mentioned autocomplete
. Is there any more info about that?
What failed in the front end test you can see this failed:
https://ci.theforeman.org/job/katello-nightly-rpm-pipeline/1631/testReport/junit/tests/test_pages/test_menu_item_Subscriptions_/
E + 'https://192.168.122.43/katello/api/v2/subscriptions/auto_complete_search?organization_id=1&search= '
E + '- Failed to load resource: the server responded with a status of 500 ()',
