https://ci.theforeman.org/job/katello-nightly-rpm-pipeline/185/
foreman-katello-nightly-test (failed)
both bats failed on:
27 check available errata
This is most probably https://bugzilla.redhat.com/show_bug.cgi?id=1741577 – we enable the CentOS CR repo and this probably now has the “broken” subscription-manager.
We can disable CR for now I think.
Untested:
Proposing we skip the failing test for the time being as this fixes pipelines across multiple footprints and re-enable it once subscription-manager has been updated. I created an issue in Forklift to track re-enabling this test.
