https://ci.theforeman.org/job/katello-nightly-rpm-pipeline/210/
foreman-katello-nightly-test (failed)
The current failure is:
TASK [foreman_proxy_content : Generate Certs] **********************************
fatal: [pipeline-katello-proxy-nightly-centos7 -> 192.168.121.161]: FAILED! => changed=true
cmd:
- foreman-proxy-certs-generate
- --foreman-proxy-fqdn
- pipeline-katello-proxy-nightly-centos7.n58.example.com
- --certs-tar
- /root/pipeline-katello-proxy-nightly-centos7.n58.example.com.tar.gz
delta: '0:00:12.457965'
end: '2019-09-22 22:45:32.535891'
msg: non-zero return code
rc: 21
start: '2019-09-22 22:45:20.077926'
stderr: |-
tput: unknown terminal "unknown"
Parameter parent-fqdn invalid: nil is not a valid string
Parameter foreman-proxy-cname invalid: Elements of the array are invalid: [] must match one of (?-mix:^(([a-zA-Z0-9]|[a-zA-Z0-9][a-zA-Z0-9\-]*[a-zA-Z0-9])\.)*([A-Za-z0-9]|[A-Za-z0-9][A-Za-z0-9\-]*[A-Za-z0-9])$)
@ekohl This looks related to https://github.com/theforeman/puppet-certs/pull/256
This uncovered a few issues. First of all, that PR was incomplete:
Then I found that we need to configure the class mapping to look for the right params class because that’s not automatic:
This uncovered a bug in kafo (which the above PR works around):
