https://ci.theforeman.org/job/katello-nightly-rpm-pipeline/259/
foreman-katello-nightly-test (passed)
upgrade is now failing when upgrading to 1.25/3.15 on hammer dependencies:
fatal: [pipeline-upgrade-katello-nightly-centos7]: FAILED! => changed=true
changes:
installed: []
updated:
- - foreman-cli
- 1.25.0-0.2.develop.20191106161048git84fa72f.el7.noarch from foreman-koji
- - foreman
- - tfm-rubygem-hammer_cli_foreman
- 0.20-0.1.pre.develop.20191106012518git9c4a2c7.el7.noarch from foreman-koji
- - katello-debug
- 3.15.0-0.1.master.el7.noarch from katello-koji
- - tfm-rubygem-pulp_file_client
- 0.1.0b5.dev01571253617-1.el7.noarch from katello-koji
- 0.20-0.1.pre.develop.20191105172131gitd29fc07.el7.noarch from foreman-koji
- - foreman-postgresql
- - foreman-proxy
- 1.25.0-0.1.develop.20191106012700gitf331898.el7.noarch from foreman-koji
- - foreman-debug
- - tfm-rubygem-dynflow
- 1.4.1-2.fm1_25.el7.noarch from foreman-koji
- - tfm-rubygem-katello
- 3.15.0-0.1.pre.master.20191106124116git4b59693.el7.noarch from katello-koji
- - foreman-selinux
- 1.25.0-0.1.develop.20191106012422gitd9ab837.el7.noarch from foreman-koji
msg: |-
Error: Package: tfm-rubygem-hammer_cli_katello-0.20.0-1.el7.noarch (@katello)
Requires: tfm-rubygem(hammer_cli_foreman) < 0.20
Removing: tfm-rubygem-hammer_cli_foreman-0.19.0-1.el7.noarch (@foreman)
tfm-rubygem(hammer_cli_foreman) = 0.19.0
Updated By: tfm-rubygem-hammer_cli_foreman-0.20-0.1.pre.develop.20191106012518git9c4a2c7.el7.noarch (foreman-koji)
tfm-rubygem(hammer_cli_foreman) = 0.20
rc: 1
results:
Loaded plugins: fastestmirror
Loading mirror speeds from cached hostfile
* base: mirror.ci.centos.org
* centos-sclo-rh: mirror.ci.centos.org
* epel: mirror.ci.centos.org
* extras: mirror.ci.centos.org
* updates: mirror.ci.centos.org
Resolving Dependencies
--> Running transaction check
---> Package foreman.noarch 0:1.24.0-0.14.RC2.el7 will be updated
---> Package foreman.noarch 0:1.25.0-0.2.develop.20191106161048git84fa72f.el7 will be an update
---> Package foreman-cli.noarch 0:1.24.0-0.14.RC2.el7 will be updated
---> Package foreman-cli.noarch 0:1.25.0-0.2.develop.20191106161048git84fa72f.el7 will be an update
---> Package foreman-debug.noarch 0:1.24.0-0.14.RC2.el7 will be updated
---> Package foreman-debug.noarch 0:1.25.0-0.2.develop.20191106161048git84fa72f.el7 will be an update
---> Package foreman-postgresql.noarch 0:1.24.0-0.14.RC2.el7 will be updated
---> Package foreman-postgresql.noarch 0:1.25.0-0.2.develop.20191106161048git84fa72f.el7 will be an update
---> Package foreman-proxy.noarch 0:1.24.0-0.4.RC2.el7 will be updated
---> Package foreman-proxy.noarch 0:1.25.0-0.1.develop.20191106012700gitf331898.el7 will be an update
---> Package foreman-selinux.noarch 0:1.24.0-0.3.RC2.el7 will be updated
---> Package foreman-selinux.noarch 0:1.25.0-0.1.develop.20191106012422gitd9ab837.el7 will be an update
---> Package katello-debug.noarch 0:3.14.0-0.3.rc1.el7 will be updated
---> Package katello-debug.noarch 0:3.15.0-0.1.master.el7 will be an update
---> Package tfm-rubygem-dynflow.noarch 0:1.4.1-1.fm1_24.el7 will be updated
---> Package tfm-rubygem-dynflow.noarch 0:1.4.1-2.fm1_25.el7 will be an update
---> Package tfm-rubygem-hammer_cli.noarch 0:0.19.0-2.el7 will be updated
---> Package tfm-rubygem-hammer_cli.noarch 0:0.20-0.1.pre.develop.20191105172131gitd29fc07.el7 will be an update
---> Package tfm-rubygem-hammer_cli_foreman.noarch 0:0.19.0-1.el7 will be updated
--> Processing Dependency: tfm-rubygem(hammer_cli_foreman) < 0.20 for package: tfm-rubygem-hammer_cli_katello-0.20.0-1.el7.noarch
---> Package tfm-rubygem-hammer_cli_foreman.noarch 0:0.20-0.1.pre.develop.20191106012518git9c4a2c7.el7 will be an update
---> Package tfm-rubygem-katello.noarch 0:3.14.0-0.4.rc1.el7 will be updated
---> Package tfm-rubygem-katello.noarch 0:3.15.0-0.1.pre.master.20191106124116git4b59693.el7 will be an update
---> Package tfm-rubygem-pulp_file_client.noarch 0:0.0.1b10.dev.1557779852-1.el7 will be updated
---> Package tfm-rubygem-pulp_file_client.noarch 0:0.1.0b5.dev01571253617-1.el7 will be an update
--> Finished Dependency Resolution
