https://ci.theforeman.org/job/katello-nightly-rpm-pipeline/313/
foreman-katello-nightly-test (passed)
this is odd, Upgrade step stop_services failed
but foreman-maintain service stop finished successfully!
fatal: [pipeline-upgrade-katello-nightly-centos7]: FAILED! => changed=true
cmd: |-
foreman-installer -v --no-colors --disable-system-checks --scenario katello --upgrade --certs-update-all --upgrade --certs-update-all --foreman-initial-admin-password changeme --puppet-server-max-active-instances 1 --puppet-server-jvm-min-heap-size 1G --puppet-server-jvm-max-heap-size 1G
delta: '0:00:32.161020'
end: '2019-12-17 23:45:07.708516'
msg: non-zero return code
rc: 1
start: '2019-12-17 23:44:35.547496'
stderr: 'tput: unknown terminal "unknown"'
stderr_lines: <omitted>
stdout: |-
[ INFO 2019-12-17T23:44:52 verbose] Executing hooks in group pre_migrations
[ INFO 2019-12-17T23:44:52 verbose] All hooks in group pre_migrations finished
[ INFO 2019-12-17T23:44:52 verbose] Executing hooks in group boot
[ INFO 2019-12-17T23:44:52 verbose] All hooks in group boot finished
[ INFO 2019-12-17T23:44:52 verbose] Executing hooks in group init
[ INFO 2019-12-17T23:44:52 verbose] All hooks in group init finished
[ INFO 2019-12-17T23:44:52 verbose] Loading default values from puppet modules...
[ INFO 2019-12-17T23:44:52 verbose] ... finished
[ INFO 2019-12-17T23:44:52 verbose] Executing hooks in group pre_values
[ INFO 2019-12-17T23:44:52 verbose] All hooks in group pre_values finished
[ INFO 2019-12-17T23:44:52 verbose] Running installer with args [["-v", "--no-colors", "--disable-system-checks", "--scenario", "katello", "--upgrade", "--certs-update-all", "--upgrade", "--certs-update-all", "--foreman-initial-admin-password", "changeme", "--puppet-server-max-active-instances", "1", "--puppet-server-jvm-min-heap-size", "1G", "--puppet-server-jvm-max-heap-size", "1G"]]
[ INFO 2019-12-17T23:44:52 verbose] Executing hooks in group pre_validations
[ WARN 2019-12-17T23:44:52 verbose] Skipping system checks.
puppet-agent-oauth-0.5.1-3.el7.noarch
[ INFO 2019-12-17T23:44:53 verbose] All hooks in group pre_validations finished
[ INFO 2019-12-17T23:44:53 verbose] Running validation checks
[ INFO 2019-12-17T23:44:53 verbose] Executing hooks in group pre_commit
[ INFO 2019-12-17T23:44:57 verbose] All hooks in group pre_commit finished
[ INFO 2019-12-17T23:44:57 verbose] Executing hooks in group pre
[ WARN 2019-12-17T23:44:57 verbose] Skipping system checks.
Marking certificate /root/ssl-build/pipeline-upgrade-katello-nightly-centos7.n6.example.com/java-client for update
Marking certificate /root/ssl-build/pipeline-upgrade-katello-nightly-centos7.n6.example.com/pipeline-upgrade-katello-nightly-centos7.n6.example.com-tomcat for update
Marking certificate /root/ssl-build/pipeline-upgrade-katello-nightly-centos7.n6.example.com/pipeline-upgrade-katello-nightly-centos7.n6.example.com-qpid-broker for update
Marking certificate /root/ssl-build/pipeline-upgrade-katello-nightly-centos7.n6.example.com/pipeline-upgrade-katello-nightly-centos7.n6.example.com-qpid-client-cert for update
Marking certificate /root/ssl-build/pipeline-upgrade-katello-nightly-centos7.n6.example.com/pipeline-upgrade-katello-nightly-centos7.n6.example.com-apache for update
Marking certificate /root/ssl-build/pipeline-upgrade-katello-nightly-centos7.n6.example.com/pulp-client for update
Marking certificate /root/ssl-build/pipeline-upgrade-katello-nightly-centos7.n6.example.com/pipeline-upgrade-katello-nightly-centos7.n6.example.com-foreman-client for update
Marking certificate /root/ssl-build/pipeline-upgrade-katello-nightly-centos7.n6.example.com/pipeline-upgrade-katello-nightly-centos7.n6.example.com-foreman-proxy for update
Marking certificate /root/ssl-build/pipeline-upgrade-katello-nightly-centos7.n6.example.com/pipeline-upgrade-katello-nightly-centos7.n6.example.com-foreman-proxy-client for update
Marking certificate /root/ssl-build/pipeline-upgrade-katello-nightly-centos7.n6.example.com/pipeline-upgrade-katello-nightly-centos7.n6.example.com-qpid-router-server for update
Marking certificate /root/ssl-build/pipeline-upgrade-katello-nightly-centos7.n6.example.com/pipeline-upgrade-katello-nightly-centos7.n6.example.com-qpid-router-client for update
Marking certificate /root/ssl-build/pipeline-upgrade-katello-nightly-centos7.n6.example.com/pipeline-upgrade-katello-nightly-centos7.n6.example.com-puppet-client for update
Upgrading, to monitor the progress on all related services, please do:
[ INFO 2019-12-17T23:44:57 verbose] Upgrading, to monitor the progress on all related services, please do:
foreman-tail | tee upgrade-$(date +%Y-%m-%d-%H%M).log
[ INFO 2019-12-17T23:44:57 verbose] foreman-tail | tee upgrade-$(date +%Y-%m-%d-%H%M).log
Upgrade Step: stop_services...
[ INFO 2019-12-17T23:45:00 verbose] Upgrade Step: stop_services...
Running Stop Services
Check if command is run as root user: [32m[1m[OK][0m
Stop applicable services: Stopping the following service(s):
rh-mongodb34-mongod, postgresql, qdrouterd, qpidd, squid, pulp_celerybeat, pulp_resource_manager, pulp_streamer, pulp_workers, tomcat, dynflowd, httpd, puppetserver, foreman-proxy
| / / - \ | / - \ | stopping foreman-proxy | stopping puppetserver | stopping httpd | stopping dynflowd | stopping tomcat | stopping pulp_workers | stopping pulp_workers / stopping pulp_streamer / stopping pulp_resource_manager / stopping pulp_celerybeat / stopping squid / stopping qpidd / stopping qdrouterd / stopping postgresql / stopping rh-mongodb34-mongod / All services stopped [32m[1m[OK][0m
Upgrade step stop_services failed. Check logs for more information.
[ERROR 2019-12-17T23:45:07 verbose] Upgrade step stop_services failed. Check logs for more information.
[ INFO 2019-12-17T23:45:07 verbose] Installer finished in 21.01761996 seconds
stdout_lines: <omitted>
