katello-nightly-rpm-pipeline 333 failed
https://ci.theforeman.org/job/katello-nightly-rpm-pipeline/333/
foreman-katello-nightly-test (failed)
Installer is failing with:
ERROR: Unrecognised option '--disable-system-checks'
@ekohl any idea?
This is fallout from merging the hooks directories. https://github.com/theforeman/foreman-installer/pull/441 was intended to fix it, but looks like it was insufficient. Bug #28732: --disable-system-checks installer option not available in upstream-nightly - Installer - Foreman was also opened for this.
The upgrade portion is failing due to a incorrect migration on my part, this is fixed via:
