https://ci.theforeman.org/job/katello-nightly-rpm-pipeline/409/
foreman-katello-nightly-test (failed)
upgrades are failing because 3.15 hasn’t been released yet and it’s looking for it. not sure if this is intentional or if we need to update it to go for 3.16 instead?
TASK [katello_repositories : Setup Katello 3.15 Repository] ********************
fatal: [pipeline-upgrade-katello-nightly-centos7]: FAILED! => changed=false
msg: 'Failure downloading https://fedorapeople.org/groups/katello/releases/yum/3.15/katello/el7/x86_64/katello-repos-latest.rpm, HTTP Error 404: Not Found'
install is failing on some tests:
Test Result (13 failures / ±0)
