https://ci.theforeman.org/job/katello-nightly-rpm-pipeline/432/
foreman-katello-nightly-test (passed)
[ERROR 2020-03-08T23:09:40 verbose] Failed to ensure postgresql, postgresql-server are absent
[Error: Execution of '/bin/rpm -e postgresql' returned 1: error: Failed dependencies:
postgresql(x86-64) = 9.2.24-2.el7_7 is needed by (installed) postgresql-server-9.2.24-2.el7_7.x86_64[0m
[Error: /Stage[main]/Main/Package[postgresql]/ensure: change from '9.2.24-2.el7_7' to 'absent' failed: Execution of '/bin/rpm -e postgresql' returned 1: error: Failed dependencies:
That’s failing on upgrading to 2.0.0-rc2. We should do a rc3 which includes
i pulled that into 2.0-stable. can we do a rc2-2 just of the installer or will that mess things up? I don’t want to wait a couple of weeks to fix this. If we can’t let’s push our rc3 now with just this fix (and a couple others in core that already got pulled in)
After some discussion on IRC, it looks like a packaging only fix is the quickest solution:
