https://ci.theforeman.org/job/katello-nightly-rpm-pipeline/446/
foreman-katello-nightly-test (passed)
I looked through the logs, but couldn’t find anything obvious. Will spin up a pipeline to see if I can find more.
When I spin up a machine and later check manually, everything works. I suspect the server is still starting up while the request is made. @sthirugn is looking into systemd socket activation which I believe will help with this. Since systemd will instantly open the socket and block on the service starting up, it should result in a more reliable connection from Apache to Foreman.
