https://ci.theforeman.org/job/katello-nightly-rpm-pipeline/479/
foreman-katello-nightly-test (passed)
fatal: [pipeline-upgrade-katello-proxy-nightly-centos7]: FAILED! =>
msg: |-
The conditional check 'foreman_installer_version_file['content'] | b64decode is version('1.21', '<')' failed. The error was: error while evaluating conditional (foreman_installer_version_file['content'] | b64decode is version('1.21', '<')): 'foreman_installer_version_file' is undefined
The error appears to be in '/root/forklift/roles/foreman_installer/tasks/install.yml': line 11, column 3, but may
be elsewhere in the file depending on the exact syntax problem.
The offending line appears to be:
- name: 'Replace certs-tar and --inital-admin parms with legacy options'
^ here
