https://ci.theforeman.org/job/katello-nightly-rpm-pipeline/504/
Looks like the repoclosure issue has been sorted, this is now failing tests in the installer with some puppet module dependency issues? @ekohl
https://ci.centos.org/job/foreman-katello-nightly-test/142/consoleFull
The katello-installer package is failing to build:
https://ci.theforeman.org/job/katello-installer-nightly-release/224/
It’s being killed after 2 hours. Earlier I’ve seen this when facter was timing out on a fact. Since facter is invoked at the start of Puppet (which we do a lot), it quickly adds up. Last time we solved it by an outgoing iptables rule on the slave to REJECT outgoing traffic to the openstack fact IP so there was no timeout. That probably wasn’t persistent.
Looks like in this case it’s taking about 6 -7 minutes for a puppet module install
. I’m blaming the often slow puppet forge this time. After a restart it looks like it’s faster.
It’s now failing on not having bumped the versions to 3.10.
