https://ci.theforeman.org/job/katello-nightly-rpm-pipeline/506/
This is failing with an installer issue:
[[31mERROR[0m [34m2018-10-22T23:56:46[0m [36mverbose[0m] (File[/etc/pki/katello/puppet/puppet_client.crt] => Certs::Keypair[puppet] => Class[Certs::Puppet] => Class[Puppet] => Class[Puppet::Server] => Class[Puppet::Server::Install] => User[puppet] => File[/etc/pki/katello/puppet/puppet_client.crt])\nTry the '--graph' option and opening the resulting '.dot' file in OmniGraffle or GraphViz
[[31mERROR[0m [34m2018-10-22T23:56:46[0m [36mverbose[0m] Failed to apply catalog: One or more resource dependency cycles detected in graph
The Katello 3.9 pipeline is failing with the same issue.
cyclic dependency has been resolved
