https://ci.theforeman.org/job/katello-nightly-rpm-pipeline/535/
Should be fixed:
So, some background to what happened:
The pulp upstream release engineer (me) did bad things by accident with libsolv, being careless about release numbers.
This is the new libsolv version that we decided to go with, to ensure the proper version will supersede if/when it lands in an elx distribution.
I fixed the version in the pulp nightly repository, but I forgot to relax the requires in pulp-rpm.spec untill this am.
The pulp nightly repos have been updated, and pulp’s nightly jobs have been re-ran. It should be safe to re-run katello’s as well.
The e-mail about the issue, for reference:
https://www.redhat.com/archives/pulp-dev/2018-October/msg00043.html
