https://ci.theforeman.org/job/katello-nightly-rpm-pipeline/584/
Failing due to intermittent failures that started with organization delete test:
@katello Please have a look as soon as possible
changed: [pipeline-katello-nightly-centos7] => (item=fb-destroy-organization.bats) => changed=true
cmd: cat /root/bats_results/fb-destroy-organization.bats.tap
delta: '0:00:00.007717'
end: '2018-12-12 14:15:13.023685'
item: fb-destroy-organization.bats
rc: 0
start: '2018-12-12 14:15:13.015968'
stderr: ''
stderr_lines: []
stdout: |-
1..1
not ok 1 Delete an Organization
# (in test file fb-destroy-organization.bats, line 15)
# `hammer organization delete --name="${ORGANIZATION}"' failed with status 70
# Task 8191caaa-e406-4cc8-9743-774b5e1be5e2 running: 0.0/1, 0%, elapsed: 00:00:00
# Task 8191caaa-e406-4cc8-9743-774b5e1be5e2 running: 0.11363636363636363/1, 11%, 0.0/s, elapsed: 00:00:02, ETA: 00:00:17
# Task 8191caaa-e406-4cc8-9743-774b5e1be5e2 running: 0.22727272727272727/1, 22%, 0.1/s, elapsed: 00:00:04, ETA: 00:00:15
# Task 8191caaa-e406-4cc8-9743-774b5e1be5e2 running: 0.4090909090909091/1, 40%, 0.1/s, elapsed: 00:00:06, ETA: 00:00:09
# Task 8191caaa-e406-4cc8-9743-774b5e1be5e2 running: 0.7272727272727273/1, 72%, 0.1/s, elapsed: 00:00:09, ETA: 00:00:03
# Task 8191caaa-e406-4cc8-9743-774b5e1be5e2 running: 0.7386363636363636/1, 73%, 0.1/s, elapsed: 00:00:11, ETA: 00:00:03
# Task 8191caaa-e406-4cc8-9743-774b5e1be5e2 error: 0.7386363636363636/1, 73%, 0.1/s, elapsed: 00:00:13, ETA: 00:00:04
# Error: PG::TRDeadlockDetected: ERROR: deadlock detected
# DETAIL: Process 24398 waits for ShareLock on transaction 14461; blocked by process 30540.
# Process 30540 waits for ShareLock on transaction 14432; blocked by process 24398.
# HINT: See server log for query details.
# : DELETE FROM "katello_pool_products" WHERE "katello_pool_products"."id" = $1
stdout_lines: <omitted>
this seems to be failing fairly consistently in almost all runs, any progress on this?
