https://ci.theforeman.org/job/katello-nightly-rpm-pipeline/596/
java.nio.file.FileSystemException: /var/lib/workspace/workspace/katello-nightly-rpm-pipeline/jobs/foreman-katello-nightly-test: Operation not permitted
at sun.nio.fs.UnixException.translateToIOException(UnixException.java:91)
at sun.nio.fs.UnixException.rethrowAsIOException(UnixException.java:102)
at sun.nio.fs.UnixException.rethrowAsIOException(UnixException.java:107)
at sun.nio.fs.UnixFileAttributeViews$Posix.setMode(UnixFileAttributeViews.java:238)
at sun.nio.fs.UnixFileAttributeViews$Posix.setPermissions(UnixFileAttributeViews.java:260)
at java.nio.file.Files.setPosixFilePermissions(Files.java:2045)
at hudson.Util.makeWritable(Util.java:337)
at hudson.Util.tryOnceDeleteFile(Util.java:297)
at hudson.Util.deleteFile(Util.java:272)
Also: hudson.remoting.Channel$CallSiteStackTrace: Remote call to slave01.rackspace.theforeman.org
at hudson.remoting.Channel.attachCallSiteStackTrace(Channel.java:1741)
at hudson.remoting.UserRequest$ExceptionResponse.retrieve(UserRequest.java:357)
at hudson.remoting.Channel.call(Channel.java:955)
at hudson.FilePath.act(FilePath.java:1072)
at hudson.FilePath.act(FilePath.java:1061)
at hudson.FilePath.deleteRecursive(FilePath.java:1268)
at org.jenkinsci.plugins.workflow.steps.DeleteDirStep$Execution.run(DeleteDirStep.java:77)
at org.jenkinsci.plugins.workflow.steps.DeleteDirStep$Execution.run(DeleteDirStep.java:69)
at org.jenkinsci.plugins.workflow.steps.SynchronousNonBlockingStepExecution$1$1.call(SynchronousNonBlockingStepExecution.java:50)
at hudson.security.ACL.impersonate(ACL.java:290)
at org.jenkinsci.plugins.workflow.steps.SynchronousNonBlockingStepExecution$1.run(SynchronousNonBlockingStepExecution.java:47)
at java.util.concurrent.Executors$RunnableAdapter.call(Executors.java:511)
Caused: java.io.IOException: Unable to delete '/var/lib/workspace/workspace/katello-nightly-rpm-pipeline/jobs/foreman-katello-nightly-test'. Tried 3 times (of a maximum of 3) waiting 0.1 sec between attempts.
at hudson.Util.deleteFile(Util.java:277)
at hudson.FilePath.deleteRecursive(FilePath.java:1305)
at hudson.FilePath.deleteContentsRecursive(FilePath.java:1314)
at hudson.FilePath.deleteRecursive(FilePath.java:1296)
at hudson.FilePath.access$1600(FilePath.java:213)
at hudson.FilePath$DeleteRecursive.invoke(FilePath.java:1274)
at hudson.FilePath$DeleteRecursive.invoke(FilePath.java:1270)
at hudson.FilePath$FileCallableWrapper.call(FilePath.java:3086)
at hudson.remoting.UserRequest.perform(UserRequest.java:212)
at hudson.remoting.UserRequest.perform(UserRequest.java:54)
at hudson.remoting.Request$2.run(Request.java:369)
at hudson.remoting.InterceptingExecutorService$1.call(InterceptingExecutorService.java:72)
at java.util.concurrent.FutureTask.run(FutureTask.java:266)
at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1149)
at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:624)
at java.lang.Thread.run(Thread.java:748)
