katello-nightly-rpm-pipeline 613 failed
https://ci.theforeman.org/job/katello-nightly-rpm-pipeline/613/
foreman-pipeline-katello-nightly-centos7-install (passed)
foreman-pipeline-katello-nightly-centos7-upgrade (failed)
TASK [foreman_installer : Run installer] ***************************************
fatal: [pipeline-up-katello-proxy-nightly-centos7]: FAILED! => changed=true
  cmd: |-
    foreman-installer -v --no-colors --disable-system-checks --scenario foreman-proxy-content  --upgrade --certs-update-all --certs-regenerate=true --certs-deploy=true --certs-tar-file="/root/pipeline-up-katello-proxy-nightly-centos7.n43.example.com.tar.gz"
  delta: '0:00:11.294442'
  end: '2020-07-22 00:16:50.085538'
  msg: non-zero return code
  rc: 1
  start: '2020-07-22 00:16:38.791096'
  stderr: |-
    tput: unknown terminal "unknown"
    ERROR: Unrecognised option '--upgrade'
    See: 'foreman-installer --help'
  stderr_lines: <omitted>
  stdout: ''
  stdout_lines: <omitted>
This is my (lousy) attemt at fixing it:
Someone with more ansible/forklift/ci knowledge should probably pick it up and push it to the finish line
