https://ci.theforeman.org/job/katello-nightly-rpm-pipeline/639/
foreman-pipeline-katello-nightly-centos7-upgrade (failed)
foreman-pipeline-katello-nightly-centos7-install (failed)
Looks like 3.17 RC1 hasn’t been released so the upgrade is failing.
msg: 'Failure downloading https://fedorapeople.org/groups/katello/releases/yum/3.17/katello/el7/x86_64/katello-repos-latest.rpm, HTTP Error 404: Not Found'
Various HTTP 403 errors:
# Could not create the repository:
# Task 01d2873c-22a9-4fe6-8fc4-735cf51a8a9f: PulpRpmClient::ApiError: Error message: the server returns an error
# HTTP status code: 403
[ekohl] ekohl https://community.theforeman.org/u/ekohl Installer
August 18jenkins: foreman-pipeline-katello-nightly-centos7-upgrade <https://ci.centos.org/job/foreman-pipeline-katello-nightly-centos7-upgrade/62/> (failed)
msg: ‘Failure downloading
HTTP Error 404: Not Found’ |jenkins: foreman-pipeline-katello-nightly-centos7-install <https://ci.centos.org/job/foreman-pipeline-katello-nightly-centos7-install/62/> (failed)
Could not create the repository: # Task
message: the server returns an error # HTTP status code: 403|
I’ve dug into this and my best guess is that it has to do with a
dependency upgrade of a lot of python3 packages within foreman-packaging
on the ~10th of august. I’ll probably need to pull in the pulp team
for some help figuring out where the issue lies.
Justin
Thanks to David Davis on the pulp team for helping me narrow down the
issue. This should fix it:
