https://ci.theforeman.org/job/katello-nightly-rpm-pipeline/649/
foreman-pipeline-katello-nightly-centos7-install (failed)
foreman-pipeline-katello-nightly-centos7-upgrade (failed)
not sure what the cause is, but this is the error:
*11:57:15* /usr/share/foreman-installer/hooks/boot/13-tuning.rb:1:in
`block (4 levels) in load': undefined method `has_custom_fact?' for
#<Kafo::HookContext:0x000000000304c8d0> (NoMethodError) *11:57:15* from
/opt/theforeman/tfm/root/usr/share/gems/gems/kafo-5.0.1/lib/kafo/hooking.rb:34:in
`instance_eval' *11:57:15* from
`block (4 levels) in load' *11:57:15* from
/opt/theforeman/tfm/root/usr/share/gems/gems/kafo-5.0.1/lib/kafo/hook_context.rb:9:in
`execute' *11:57:15* from
/opt/theforeman/tfm/root/usr/share/gems/gems/kafo-5.0.1/lib/kafo/hooking.rb:51:in
`block in execute' *11:57:15* from
/opt/theforeman/tfm/root/usr/share/gems/gems/kafo-5.0.1/lib/kafo/hooking.rb:49:in
`each' *11:57:15* from
/opt/theforeman/tfm/root/usr/share/gems/gems/kafo-5.0.1/lib/kafo/kafo_configure.rb:89:in
`initialize' *11:57:15* from
/opt/theforeman/tfm/root/usr/share/gems/gems/clamp-1.1.2/lib/clamp/command.rb:132:in
`new' *11:57:15* from
`run' *11:57:15* from
/opt/theforeman/tfm/root/usr/share/gems/gems/kafo-5.0.1/lib/kafo/kafo_configure.rb:162:in
`run' *11:57:15* from /sbin/foreman-installer:8:in `<main>'
Looks like this is what broke it:
Yes, that was my bad. I assumed we had already packaged Kafo 5.1.0. The RPM side has been merged now:
The Debian side hasn’t yet.
