https://ci.theforeman.org/job/katello-nightly-rpm-pipeline/652/
This got passed the previous failure, but the upgrade is now failing:
/etc/foreman-installer/scenarios.d/katello.migrations/190111131058-reset-puppetserver-versions.rb:7:in `block (2 levels) in load_migrations': undefined local variable or method `server' for #<Kafo::MigrationContext:0x00000001cc3188> (NameError)
from /usr/share/gems/gems/kafo-2.1.0/lib/kafo/migrations.rb:25:in `instance_eval'
from /usr/share/gems/gems/kafo-2.1.0/lib/kafo/migrations.rb:25:in `block (2 levels) in load_migrations'
from /usr/share/gems/gems/kafo-2.1.0/lib/kafo/migration_context.rb:10:in `instance_eval'
from /usr/share/gems/gems/kafo-2.1.0/lib/kafo/migration_context.rb:10:in `execute'
from /usr/share/gems/gems/kafo-2.1.0/lib/kafo/migrations.rb:38:in `block in run'
from /usr/share/gems/gems/kafo-2.1.0/lib/kafo/migrations.rb:35:in `each'
from /usr/share/gems/gems/kafo-2.1.0/lib/kafo/migrations.rb:35:in `run'
from /usr/share/gems/gems/kafo-2.1.0/lib/kafo/configuration.rb:283:in `run_migrations'
from /usr/share/gems/gems/kafo-2.1.0/lib/kafo/kafo_configure.rb:65:in `initialize'
from /usr/share/gems/gems/clamp-1.1.2/lib/clamp/command.rb:132:in `new'
from /usr/share/gems/gems/clamp-1.1.2/lib/clamp/command.rb:132:in `run'
from /usr/share/gems/gems/kafo-2.1.0/lib/kafo/kafo_configure.rb:163:in `run'
from /sbin/foreman-installer:8:in `<main>'
@ekohl this looks like its caused by https://github.com/theforeman/foreman-installer/commit/e231869242bd89263bb23e88f4c01be784305454
I see it requires https://github.com/theforeman/puppet-puppet/pull/668
Do we need a puppet-puppet release?
Oh i see, one was just released. We wait!
