https://ci.theforeman.org/job/katello-nightly-rpm-pipeline/670/
Not sure where this issue comes from:
Upgrade test] Fetching upstream changes from https://github.com/theforeman/foreman-infra
[Upgrade test] > /usr/bin/git --version # timeout=10
[Upgrade test] > /usr/bin/git fetch --tags --progress https://github.com/theforeman/foreman-infra +refs/heads/*:refs/remotes/origin/*
[Install test] ERROR: Failed to clean the workspace
[Install test] java.io.IOException: Unable to delete '/var/lib/workspace/workspace/katello-nightly-rpm-pipeline'. Tried 3 times (of a maximum of 3) waiting 0.1 sec between attempts.
A root-owned subdirectory existed on that slave and caused the problem.
