foreman-pipeline-katello-nightly-centos7-install (failed)
foreman-pipeline-katello-nightly-centos7-upgrade (failed)
[2020-11-08T23:33:08.630Z] not ok 36 install errata remotely (katello-agent)
[2020-11-08T23:33:08.630Z] # (from function `tPackageExists' in file os_helper.bash, line 80,
[2020-11-08T23:33:08.630Z] # in test file fb-content-katello.bats, line 245)
[2020-11-08T23:33:08.630Z] # `tPackageExists walrus-5.21' failed
[2020-11-08T23:33:08.630Z] # Task aa730812-8ca5-4d26-9ee1-7695bd69703b running: 0.67/1, 67%, elapsed: 00:00:00
[2020-11-08T23:33:08.630Z] # Task aa730812-8ca5-4d26-9ee1-7695bd69703b warning: 1.0/1, 100%, elapsed: 00:00:02
[2020-11-08T23:33:08.630Z] # Error: 400 Bad Request
The only “Bad Request” I can find is:
2020-11-08T23:24:36 [E|kat|] POST: https://pipeline-katello-server-nightly-centos7.n58.example.com/pulp/api/v2/consumers/95a5b0dc-eff6-4945-9182-85f2a1a1e7f2/actions/content/install//: {"units":[{"type_id":"erratum","unit_key":{"id":"RHEA-2012:0055"}}],"options":{"importkeys":true}}: {"content_type"=>"application/json", "accept"=>"application/json"}
| 400 Bad Request: {"http_request_method": "POST", "exception": null, "error_message": "Consumer has no RPM unit profile", "_href": "/pulp/api/v2/consumers/95a5b0dc-eff6-4945-9182-85f2a1a1e7f2/actions/content/install//", "http_status": 400, "error": {"code": "PLP0000", "data": {}, "description": "Consumer has no RPM unit profile", "sub_errors": []}, "args": ["Consumer has no RPM unit profile"], "traceback": null}
2020-11-08T23:24:36 [E|bac|] 400 Bad Request (RestClient::BadRequest)
(totally different timestamp, tho?! – but that’s probably due to the way the reporting happens, it doesn’t print anything until all tests are done, which screws the timestamps)
Ping @katello
