foreman-pipeline-katello-nightly-centos7-upgrade (failed)
foreman-pipeline-katello-nightly-centos7-install (failed)
foreman-pipeline-katello-nightly-centos8-install (failed)
Looks like upgrade failed on a test, the others timed out. This is related to the problem we’re seeing in smoker where sometimes there’s a timeout. We’ve traced this back to the latest chromium version (https://bodhi.fedoraproject.org/updates/FEDORA-EPEL-2020-2f9004588a) but unsure what to do about it now. Perhaps this can mitigate it a bit:
The test failure seen in these tends to be transient, with content proxy syncs hitting a proxy error. From some investigation, this seems to happen right around the 60 second proxy timeout that is default. I opened https://github.com/theforeman/puppet-pulpcore/pull/160 to allow us to configure this (and other properties) with a default set to 5 minutes to see if it mitigates this.
