katello-nightly-rpm-pipeline 816 failed
https://ci.theforeman.org/job/katello-nightly-rpm-pipeline/816/
Looks like proxy is failing to load:
[ INFO 2019-03-11T22:26:09 verbose]  Class[Foreman_proxy::Register]: Scheduling refresh of Foreman_smartproxy[pipeline-katello-nightly-centos7.n40.example.com]
[ERROR 2019-03-11T22:26:11 verbose]  Proxy pipeline-katello-nightly-centos7.n40.example.com has failed to load one or more features (HTTPBoot, Puppet, Puppet CA, TFTP, Templates, Logs), check /var/log/foreman-proxy/proxy.log for configuration errors
[ERROR 2019-03-11T22:26:11 verbose] /usr/share/foreman-installer/modules/foreman/lib/puppet/provider/foreman_smartproxy/rest_v3.rb:70:in `validate_features!'
[ERROR 2019-03-11T22:26:11 verbose] /usr/share/foreman-installer/modules/foreman/lib/puppet/provider/foreman_smartproxy/rest_v3.rb:24:in `create'
[ERROR 2019-03-11T22:26:11 verbose] /opt/puppetlabs/puppet/lib/ruby/vendor_ruby/puppet/property/ensure.rb:16:in `block in defaultvalues'
[ERROR 2019-03-11T22:26:11 verbose] /opt/puppetlabs/puppet/lib/ruby/vendor_ruby/puppet/property.rb:491:in `set'
[ERROR 2019-03-11T22:26:11 verbose] /opt/puppetlabs/puppet/lib/ruby/vendor_ruby/puppet/property.rb:568:in `sync'
[ERROR 2019-03-11T22:26:11 verbose] /opt/puppetlabs/puppet/lib/ruby/vendor_ruby/puppet/transaction/resource_harness.rb:238:in `sync'
[ERROR 2019-03-11T22:26:11 verbose] /opt/puppetlabs/puppet/lib/ruby/vendor_ruby/puppet/transaction/resource_harness.rb:134:in `sync_if_needed'
[ERROR 2019-03-11T22:26:11 verbose] /opt/puppetlabs/puppet/lib/ruby/vendor_ruby/puppet/transaction/resource_harness.rb:80:in `perform_changes'
[ERROR 2019-03-11T22:26:11 verbose] /opt/puppetlabs/puppet/lib/ruby/vendor_ruby/puppet/transaction/resource_harness.rb:21:in `evaluate'
[ERROR 2019-03-11T22:26:11 verbose] /opt/puppetlabs/puppet/lib/ruby/vendor_ruby/puppet/transaction.rb:259:in `apply'
[ERROR 2019-03-11T22:26:11 verbose] /opt/puppetlabs/puppet/lib/ruby/vendor_ruby/puppet/transaction.rb:279:in `eval_resource'
[ERROR 2019-03-11T22:26:11 verbose] /opt/puppetlabs/puppet/lib/ruby/vendor_ruby/puppet/transaction.rb:183:in `call'
[ERROR 2019-03-11T22:26:11 verbose] /opt/puppetlabs/puppet/lib/ruby/vendor_ruby/puppet/transaction.rb:183:in `block (2 levels) in evaluate'
[ERROR 2019-03-11T22:26:11 verbose] /opt/puppetlabs/puppet/lib/ruby/vendor_ruby/puppet/util.rb:519:in `block in thinmark'
[ERROR 2019-03-11T22:26:11 verbose] /opt/puppetlabs/puppet/lib/ruby/2.4.0/benchmark.rb:308:in `realtime'
[ERROR 2019-03-11T22:26:11 verbose] /opt/puppetlabs/puppet/lib/ruby/vendor_ruby/puppet/util.rb:518:in `thinmark'
[ERROR 2019-03-11T22:26:11 verbose] /opt/puppetlabs/puppet/lib/ruby/vendor_ruby/puppet/transaction.rb:183:in `block in evaluate'
[ERROR 2019-03-11T22:26:11 verbose] /opt/puppetlabs/puppet/lib/ruby/vendor_ruby/puppet/graph/relationship_graph.rb:121:in `traverse'
[ERROR 2019-03-11T22:26:11 verbose] /opt/puppetlabs/puppet/lib/ruby/vendor_ruby/puppet/transaction.rb:173:in `evaluate'
[ERROR 2019-03-11T22:26:11 verbose] /opt/puppetlabs/puppet/lib/ruby/vendor_ruby/puppet/resource/catalog.rb:239:in `block (2 levels) in apply'
[ERROR 2019-03-11T22:26:11 verbose] /opt/puppetlabs/puppet/lib/ruby/vendor_ruby/puppet/resource/catalog.rb:238:in `block in apply'
[ERROR 2019-03-11T22:26:11 verbose] /opt/puppetlabs/puppet/lib/ruby/vendor_ruby/puppet/util/log.rb:156:in `with_destination'
[ERROR 2019-03-11T22:26:11 verbose] /opt/puppetlabs/puppet/lib/ruby/vendor_ruby/puppet/transaction/report.rb:146:in `as_logging_destination'
[ERROR 2019-03-11T22:26:11 verbose] /opt/puppetlabs/puppet/lib/ruby/vendor_ruby/puppet/resource/catalog.rb:237:in `apply'
[ERROR 2019-03-11T22:26:11 verbose] /opt/puppetlabs/puppet/lib/ruby/vendor_ruby/puppet/configurer.rb:186:in `block (2 levels) in apply_catalog'
[ERROR 2019-03-11T22:26:11 verbose] /opt/puppetlabs/puppet/lib/ruby/vendor_ruby/puppet/configurer.rb:185:in `block in apply_catalog'
[ERROR 2019-03-11T22:26:11 verbose] /opt/puppetlabs/puppet/lib/ruby/vendor_ruby/puppet/util.rb:232:in `block in benchmark'
[ERROR 2019-03-11T22:26:11 verbose] /opt/puppetlabs/puppet/lib/ruby/vendor_ruby/puppet/util.rb:231:in `benchmark'
[ERROR 2019-03-11T22:26:11 verbose] /opt/puppetlabs/puppet/lib/ruby/vendor_ruby/puppet/configurer.rb:184:in `apply_catalog'
[ERROR 2019-03-11T22:26:11 verbose] /opt/puppetlabs/puppet/lib/ruby/vendor_ruby/puppet/configurer.rb:369:in `run_internal'
[ERROR 2019-03-11T22:26:11 verbose] /opt/puppetlabs/puppet/lib/ruby/vendor_ruby/puppet/configurer.rb:237:in `block in run'
[ERROR 2019-03-11T22:26:11 verbose] /opt/puppetlabs/puppet/lib/ruby/vendor_ruby/puppet/context.rb:65:in `override'
[ERROR 2019-03-11T22:26:11 verbose] /opt/puppetlabs/puppet/lib/ruby/vendor_ruby/puppet.rb:260:in `override'
[ERROR 2019-03-11T22:26:11 verbose] /opt/puppetlabs/puppet/lib/ruby/vendor_ruby/puppet/configurer.rb:211:in `run'
[ERROR 2019-03-11T22:26:11 verbose] /opt/puppetlabs/puppet/lib/ruby/vendor_ruby/puppet/application/apply.rb:355:in `apply_catalog'
[ERROR 2019-03-11T22:26:11 verbose] /opt/puppetlabs/puppet/lib/ruby/vendor_ruby/puppet/application/apply.rb:280:in `block (2 levels) in main'
[ERROR 2019-03-11T22:26:11 verbose] /opt/puppetlabs/puppet/lib/ruby/vendor_ruby/puppet/application/apply.rb:280:in `block in main'
[ERROR 2019-03-11T22:26:11 verbose] /opt/puppetlabs/puppet/lib/ruby/vendor_ruby/puppet/application/apply.rb:233:in `main'
[ERROR 2019-03-11T22:26:11 verbose] /opt/puppetlabs/puppet/lib/ruby/vendor_ruby/puppet/application/apply.rb:174:in `run_command'
[ERROR 2019-03-11T22:26:11 verbose] /opt/puppetlabs/puppet/lib/ruby/vendor_ruby/puppet/application.rb:375:in `block in run'
[ERROR 2019-03-11T22:26:11 verbose] /opt/puppetlabs/puppet/lib/ruby/vendor_ruby/puppet/util.rb:667:in `exit_on_fail'
[ERROR 2019-03-11T22:26:11 verbose] /opt/puppetlabs/puppet/lib/ruby/vendor_ruby/puppet/application.rb:375:in `run'
[ERROR 2019-03-11T22:26:11 verbose] /opt/puppetlabs/puppet/lib/ruby/vendor_ruby/puppet/util/command_line.rb:135:in `run'
[ERROR 2019-03-11T22:26:11 verbose] /opt/puppetlabs/puppet/lib/ruby/vendor_ruby/puppet/util/command_line.rb:73:in `execute'
[ERROR 2019-03-11T22:26:11 verbose] /opt/puppetlabs/puppet/bin/puppet:5:in `<main>'
[ERROR 2019-03-11T22:26:11 verbose]  /Stage[main]/Foreman_proxy::Register/Foreman_smartproxy[pipeline-katello-nightly-centos7.n40.example.com]/ensure: change from 'absent' to 'present' failed: Proxy pipeline-katello-nightly-centos7.n40.example.com has failed to load one or more features (HTTPBoot, Puppet, Puppet CA, TFTP, Templates, Logs), check /var/log/foreman-proxy/proxy.log for configuration errors
Looking in proxy.log, only error is:
 2019-03-11T22:26:09  [W] TCPServer Error: Address already in use - bind(2)
but it still seems to start successfully
Looking at the logs looks like all the calls for registering the proxy and refreshing features succeeded, not sure why the installer is saying that all the features didn’t load - maybe related to the new capabilities api? cc @Justin_Sherrill @ekohl
Looking into this.
Justin
https://projects.theforeman.org/issues/26331
On my reproducer this appeared to solve the issue
