https://ci.theforeman.org/job/katello-nightly-rpm-pipeline/826/
Upgrade fails with:
Transaction check error:
file /etc/pki/rpm-gpg/RPM-GPG-KEY-foreman from install of foreman-release-1.21.0-1.el7.noarch conflicts with file from package foreman-client-release-1.20.2-1.el7.noarch
https://github.com/theforeman/foreman-packaging/pull/3534
Install fails with:
not ok 3 sync proxy
# (in test file fb-proxy.bats, line 26)
# `hammer capsule content synchronize --id=$PROXY_ID' failed with status 70
# Task 0a05e7b3-d9d8-4588-8135-b6c6d28978af running: 0.0/1, 0%, elapsed: 00:00:00
# Task 0a05e7b3-d9d8-4588-8135-b6c6d28978af running: 0.0594059405940594/1, 5%, 0.0/s, elapsed: 00:00:02, ETA: 00:00:34
# Task 0a05e7b3-d9d8-4588-8135-b6c6d28978af running: 0.0594059405940594/1, 5%, 0.0/s, elapsed: 00:00:04, ETA: 00:01:08
# Task 0a05e7b3-d9d8-4588-8135-b6c6d28978af running: 0.0594059405940594/1, 5%, 0.0/s, elapsed: 00:00:06, ETA: 00:01:42
# Task 0a05e7b3-d9d8-4588-8135-b6c6d28978af running: 0.0594059405940594/1, 5%, 0.0/s, elapsed: 00:00:08, ETA: 00:02:16
# Task 0a05e7b3-d9d8-4588-8135-b6c6d28978af running: 0.0594059405940594/1, 5%, 0.0/s, elapsed: 00:00:10, ETA: 00:02:50
# Task 0a05e7b3-d9d8-4588-8135-b6c6d28978af running: 0.0594059405940594/1, 5%, 0.0/s, elapsed: 00:00:13, ETA: 00:03:24
# Task 0a05e7b3-d9d8-4588-8135-b6c6d28978af running: 0.28217821782178215/1, 28%, 0.0/s, elapsed: 00:00:15, ETA: 00:00:42
# Task 0a05e7b3-d9d8-4588-8135-b6c6d28978af running: 0.5544554455445545/1, 55%, 0.0/s, elapsed: 00:00:17, ETA: 00:00:11
# Task 0a05e7b3-d9d8-4588-8135-b6c6d28978af warning: 1.0/1, 100%, 0.1/s, elapsed: 00:00:19
# Error: PLP0000: Importer indicated a failed response
The install failure is because the Proxy tries to sync Puppet content and fails. I am not sure why it fails, tho.
