Katello nightly web application couldn't be started
I could not access katello web page after restarted httpd server.httpd servers is running.
I got below error
Web application could not be started
An error occurred while starting up the preloader: it did not write a startup response in time. Please read this article for more information about this problem.
Raw process output:
–> No passenger_native_support.so found for current Ruby interpreter.
This library provides various optimized routines that make
Phusion Passenger faster. Please run ‘sudo yum install passenger-devel-4.0.53’
so that Phusion Passenger can compile one on the next run.
–> Continuing without passenger_native_support.so.
/usr/share/foreman/lib/foreman.rb:8: warning: already initialized constant Foreman::UUID_REGEXP
/usr/share/foreman/lib/foreman.rb:8: warning: previous definition of UUID_REGEXP was here
Error ID
c8ea18c1
Application root
/usr/share/foreman
Environment (value of RAILS_ENV, RACK_ENV, WSGI_ENV, NODE_ENV and PASSENGER_APP_ENV)
production
Ruby interpreter command
/usr/bin/tfm-ruby
User and groups
uid=997(foreman) gid=994(foreman) groups=994(foreman),992(qpidd)
Environment variables
LANG=C
PATH=/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin
NOTIFY_SOCKET=/run/systemd/notify
PASSENGER_DEBUG_DIR=/tmp/passenger.spawn-debug.XXXXTkJxf9
USER=foreman
LOGNAME=foreman
SHELL=/bin/false
HOME=/usr/share/foreman
PWD=/usr/share/foreman
IN_PASSENGER=1
PYTHONUNBUFFERED=1
NODE_PATH=/usr/share/passenger/node
RAILS_ENV=production
RACK_ENV=production
WSGI_ENV=production
NODE_ENV=production
PASSENGER_APP_ENV=production
SERVER_PROTOCOL=HTTP/1.1
SERVER_SOFTWARE=Apache
DOCUMENT_ROOT=/usr/share/foreman/public
SERVER_ADMIN=[no address given]
QUERY_STRING=
SERVER_NAME=ol07ktl00.sstech.com
REMOTE_PORT=60172
REMOTE_ADDR=127.0.0.1
SERVER_PORT=80
REQUEST_METHOD=HEAD
SERVER_ADDR=127.0.0.1
REQUEST_URI=/
Ulimits
Unknown
System metrics
------------- General -------------
Kernel version : 4.14.35-1902.0.18.el7uek.x86_64
Uptime : 7h 42m 36s
Load averages : 1.90%, 1.65%, 1.33%
Fork rate : unknown
------------- CPU -------------
Number of CPUs : 6
Average CPU usage : 44% – 31% user, 0% nice, 12% system, 56% idle
CPU 1 : 20% – 20% user, 0% nice, 0% system, 80% idle
CPU 2 : 33% – 17% user, 0% nice, 17% system, 67% idle
CPU 3 : 0% – 0% user, 0% nice, 0% system, 100% idle
CPU 4 : 100% – 100% user, 0% nice, 0% system, 0% idle
CPU 5 : 83% – 50% user, 0% nice, 33% system, 17% idle
CPU 6 : 25% – 0% user, 0% nice, 25% system, 75% idle
I/O pressure : 0%
CPU 1 : 0%
CPU 2 : 0%
CPU 3 : 0%
CPU 4 : 0%
CPU 5 : 0%
CPU 6 : 0%
Interference from other VMs: 0%
CPU 1 : 0%
CPU 2 : 0%
CPU 3 : 0%
CPU 4 : 0%
CPU 5 : 0%
CPU 6 : 0%
------------- Memory -------------
RAM total : 16006 MB
RAM used : 5834 MB (36%)
RAM free : 10172 MB
Swap total : 16383 MB
Swap used : 0 MB (0%)
Swap free : 16383 MB
Swap in : unknown
Swap out : unknown
General Ruby interpreter information
RUBY_VERSION = 2.5.3
RUBY_PLATFORM = x86_64-linux
RUBY_ENGINE = ruby
RubyGems version = 2.7.6
RubyGems paths = ["/opt/theforeman/tfm/root/usr/share/gems", “/opt/theforeman/tfm-ror52/root/usr/share/gems”, “/usr/share/foreman/.gem/ruby”, “/opt/rh/rh-ruby25/root/usr/share/gems”, “/opt/rh/rh-ruby25/root/usr/local/share/gems/opt/theforeman/tfm-ror52/root/usr/share/gems”, “/opt/rh/rh-ruby25/root/usr/local/share/gems”]
Ruby configuration (RbConfig::CONFIG)
DESTDIR =
MAJOR = 2
MINOR = 5
TEENY = 3
PATCHLEVEL = 105
INSTALL = /usr/bin/install -c
EXEEXT =
prefix = /opt/rh/rh-ruby25/root/usr
ruby_install_name = ruby
RUBY_INSTALL_NAME = ruby
RUBY_SO_NAME = ruby
exec = exec
ruby_pc = ruby.pc
PACKAGE = ruby
BUILTIN_TRANSSRCS = enc/trans/newline.c
USE_RUBYGEMS = YES
MANTYPE = doc
OPTIONAL_PRELUDES = ./abrt_prelude.rb
vendorarchhdrdir = /opt/rh/rh-ruby25/root/usr/include/vendor_ruby/x86_64-linux
sitearchhdrdir = /opt/rh/rh-ruby25/root/usr/include/site_ruby/x86_64-linux
rubyarchhdrdir = /opt/rh/rh-ruby25/root/usr/include
vendorhdrdir = /opt/rh/rh-ruby25/root/usr/include/vendor_ruby
sitehdrdir = /opt/rh/rh-ruby25/root/usr/include/site_ruby
rubyhdrdir = /opt/rh/rh-ruby25/root/usr/include
RUBY_SEARCH_PATH =
UNIVERSAL_INTS =
UNIVERSAL_ARCHNAMES =
configure_args = ‘–build=x86_64-redhat-linux-gnu’ ‘–host=x86_64-redhat-linux-gnu’ ‘–program-prefix=’ ‘–disable-dependency-tracking’ ‘–prefix=/opt/rh/rh-ruby25/root/usr’ ‘–exec-prefix=/opt/rh/rh-ruby25/root/usr’ ‘–bindir=/opt/rh/rh-ruby25/root/usr/bin’ ‘–sbindir=/opt/rh/rh-ruby25/root/usr/sbin’ ‘–sysconfdir=/etc/opt/rh/rh-ruby25’ ‘–datadir=/opt/rh/rh-ruby25/root/usr/share’ ‘–includedir=/opt/rh/rh-ruby25/root/usr/include’ ‘–libdir=/opt/rh/rh-ruby25/root/usr/lib64’ ‘–libexecdir=/opt/rh/rh-ruby25/root/usr/libexec’ ‘–localstatedir=/var/opt/rh/rh-ruby25’ ‘–sharedstatedir=/var/opt/rh/rh-ruby25/lib’ ‘–mandir=/opt/rh/rh-ruby25/root/usr/share/man’ ‘–infodir=/opt/rh/rh-ruby25/root/usr/share/info’ ‘–with-rubylibprefix=/opt/rh/rh-ruby25/root/usr/share/ruby’ ‘–with-archlibdir=/opt/rh/rh-ruby25/root/usr/lib64’ ‘–with-rubyarchprefix=/opt/rh/rh-ruby25/root/usr/lib64/ruby’ ‘–with-sitedir=/opt/rh/rh-ruby25/root/usr/local/share/ruby/site_ruby’ ‘–with-sitearchdir=/opt/rh/rh-ruby25/root/usr/local/lib64/ruby/site_ruby’ ‘–with-vendordir=/opt/rh/rh-ruby25/root/usr/share/ruby/vendor_ruby’ ‘–with-vendorarchdir=/opt/rh/rh-ruby25/root/usr/lib64/ruby/vendor_ruby’ ‘–with-rubyhdrdir=/opt/rh/rh-ruby25/root/usr/include’ ‘–with-rubyarchhdrdir=/opt/rh/rh-ruby25/root/usr/include’ ‘–with-sitearchhdrdir=$(sitehdrdir)/$(arch)’ ‘–with-vendorarchhdrdir=$(vendorhdrdir)/$(arch)’ ‘–with-rubygemsdir=/opt/rh/rh-ruby25/root/usr/share/rubygems’ ‘–with-ruby-pc=ruby.pc’ ‘–with-compress-debug-sections=no’ ‘–disable-rpath’ ‘–enable-shared’ ‘–with-ruby-version=’ ‘–enable-multiarch’ ‘–with-prelude=./abrt_prelude.rb’ ‘build_alias=x86_64-redhat-linux-gnu’ ‘host_alias=x86_64-redhat-linux-gnu’ ‘CFLAGS=-O2 -g -pipe -Wall -Wp,-D_FORTIFY_SOURCE=2 -fexceptions -fstack-protector-strong --param=ssp-buffer-size=4 -grecord-gcc-switches -m64 -mtune=generic’ 'LDFLAGS=-Wl,-z,relro ’ ‘CXXFLAGS=-O2 -g -pipe -Wall -Wp,-D_FORTIFY_SOURCE=2 -fexceptions -fstack-protector-strong --param=ssp-buffer-size=4 -grecord-gcc-switches -m64 -mtune=generic’
CONFIGURE = configure
rubygemsdir = /opt/rh/rh-ruby25/root/usr/share/rubygems
vendorarchdir = /opt/rh/rh-ruby25/root/usr/lib64/ruby/vendor_ruby
vendorlibdir = /opt/rh/rh-ruby25/root/usr/share/ruby/vendor_ruby
vendordir = /opt/rh/rh-ruby25/root/usr/share/ruby/vendor_ruby
sitearchdir = /opt/rh/rh-ruby25/root/usr/local/lib64/ruby/site_ruby
sitelibdir = /opt/rh/rh-ruby25/root/usr/local/share/ruby/site_ruby
sitedir = /opt/rh/rh-ruby25/root/usr/local/share/ruby/site_ruby
rubyarchdir = /opt/rh/rh-ruby25/root/usr/lib64/ruby
rubylibdir = /opt/rh/rh-ruby25/root/usr/share/ruby
ruby_version_dir_name =
ruby_version = 2.5.0
sitearch = x86_64-linux
arch = x86_64-linux
sitearchincludedir = /opt/rh/rh-ruby25/root/usr/include/x86_64-linux
sitearchlibdir = /opt/rh/rh-ruby25/root/usr/lib64/x86_64-linux
libdirname = archlibdir
RUBY_EXEC_PREFIX = /opt/rh/rh-ruby25/root/usr
RUBY_LIB_VERSION = 2.5.0
RUBY_LIB_VERSION_STYLE = 3 /* full */
RI_BASE_NAME = ri
ridir = /opt/rh/rh-ruby25/root/usr/share/ri
rubysitearchprefix = /opt/rh/rh-ruby25/root/usr/lib64/x86_64-linux/ruby
rubyarchprefix = /opt/rh/rh-ruby25/root/usr/lib64/ruby
MAKEFILES = Makefile GNUmakefile
PLATFORM_DIR =
THREAD_MODEL = pthread
SYMBOL_PREFIX =
EXPORT_PREFIX =
COMMON_HEADERS =
COMMON_MACROS =
COMMON_LIBS =
MAINLIBS =
ENABLE_SHARED = yes
DLDLIBS = -lc
SOLIBS = -lpthread -ldl -lcrypt -lm
LIBRUBYARG_SHARED = -lruby
LIBRUBYARG_STATIC = -lruby-static
LIBRUBYARG = -lruby
LIBRUBY = libruby.so.2.5.3
LIBRUBY_ALIASES = libruby.so.2.5 libruby.so
LIBRUBY_SONAME = libruby.so.2.5
LIBRUBY_SO = libruby.so.2.5.3
LIBRUBY_A = libruby-static.a
RUBYW_INSTALL_NAME =
rubyw_install_name =
EXTDLDFLAGS =
EXTLDFLAGS =
strict_warnflags = -std=gnu99
warnflags = -Wall -Wextra -Wno-unused-parameter -Wno-parentheses -Wno-long-long -Wno-missing-field-initializers -Wno-tautological-compare -Wno-parentheses-equality -Wno-constant-logical-operand -Wno-self-assign -Wunused-variable -Wimplicit-int -Wpointer-arith -Wwrite-strings -Wdeclaration-after-statement -Wimplicit-function-declaration -Wdeprecated-declarations -Wno-packed-bitfield-compat -Wsuggest-attribute=noreturn -Wsuggest-attribute=format
debugflags = -ggdb3
optflags = -O3
NULLCMD = :
ENABLE_DEBUG_ENV =
DLNOBJ = dln.o
INSTALL_STATIC_LIBRARY = no
EXECUTABLE_EXTS =
ARCHFILE =
LIBRUBY_RELATIVE = no
EXTOUT = .ext
PREP = miniruby
CROSS_COMPILING = no
TEST_RUNNABLE = yes
rubylibprefix = /opt/rh/rh-ruby25/root/usr/share/ruby
setup = Setup
ENCSTATIC =
EXTSTATIC =
STRIP = strip -S -x
SOEXT = so
TRY_LINK =
PRELOADENV = LD_PRELOAD
LIBPATHENV = LD_LIBRARY_PATH
RPATHFLAG =
LIBPATHFLAG = -L%s
LINK_SO =
ASMEXT = S
LIBEXT = a
DLEXT2 =
DLEXT = so
LDSHAREDXX = g++ -shared
LDSHARED = gcc -shared
CCDLFLAGS = -fPIC
STATIC =
ARCH_FLAG = -m64
DLDFLAGS = -Wl,-z,relro -m64
ALLOCA =
dsymutil =
codesign =
POSTLINK = :
WERRORFLAG = -Werror
CHDIR = cd -P
RMALL = rm -fr
RMDIRS = rmdir --ignore-fail-on-non-empty -p
RMDIR = rmdir --ignore-fail-on-non-empty
CP = cp
RM = rm -f
PKG_CONFIG = pkg-config
DOXYGEN =
DOT =
MAKEDIRS = /usr/bin/mkdir -p
MKDIR_P = /usr/bin/mkdir -p
INSTALL_DATA = /usr/bin/install -c -m 644
INSTALL_SCRIPT = /usr/bin/install -c
INSTALL_PROGRAM = /usr/bin/install -c
SET_MAKE =
LN_S = ln -s
NM = nm
DLLWRAP =
WINDRES =
OBJCOPY = :
OBJDUMP = objdump
ASFLAGS =
AS = as
ARFLAGS = rcD
AR = ar
RANLIB = ranlib
try_header =
CC_VERSION_MESSAGE = gcc (GCC) 4.8.5 20150623 (Red Hat 4.8.5-36)
Copyright © 2015 Free Software Foundation, Inc.
This is free software; see the source for copying conditions. There is NO
warranty; not even for MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.
CC_VERSION = gcc --version
CSRCFLAG =
COUTFLAG = -o
OUTFLAG = -o
CPPOUTFILE = -o conftest.i
GNU_LD = yes
LD = ld
GCC = yes
EGREP = /usr/bin/grep -E
CPP = gcc -E
CXXFLAGS = -O2 -g -pipe -Wall -Wp,-D_FORTIFY_SOURCE=2 -fexceptions -fstack-protector-strong --param=ssp-buffer-size=4 -grecord-gcc-switches -mtune=generic
CXX = g++
OBJEXT = o
CPPFLAGS =
LDFLAGS = -L. -Wl,-z,relro -fstack-protector-strong -rdynamic -Wl,-export-dynamic
CFLAGS = -O2 -g -pipe -Wall -Wp,-D_FORTIFY_SOURCE=2 -fexceptions -fstack-protector-strong --param=ssp-buffer-size=4 -grecord-gcc-switches -mtune=generic -fPIC
CC = gcc
target_os = linux
target_vendor = redhat
target_cpu = x86_64
target = x86_64-redhat-linux-gnu
host_os = linux-gnu
host_vendor = redhat
host_cpu = x86_64
host = x86_64-redhat-linux-gnu
RUBY_VERSION_NAME = ruby-
RUBYW_BASE_NAME = rubyw
RUBY_BASE_NAME = ruby
build_os = linux-gnu
build_vendor = redhat
build_cpu = x86_64
build = x86_64-redhat-linux-gnu
RUBY_API_VERSION = 2.5
RUBY_PROGRAM_VERSION = 2.5.3
HAVE_GIT = yes
GIT = git
cxxflags = -O3 -ggdb3 -Wall -Wextra -Wno-unused-parameter -Wno-parentheses -Wno-long-long -Wno-missing-field-initializers -Wno-tautological-compare -Wno-parentheses-equality -Wno-constant-logical-operand -Wno-self-assign -Wunused-variable -Wimplicit-int -Wpointer-arith -Wwrite-strings -Wdeclaration-after-statement -Wimplicit-function-declaration -Wdeprecated-declarations -Wno-packed-bitfield-compat -Wsuggest-attribute=noreturn -Wsuggest-attribute=format
cppflags =
cflags = -O3 -ggdb3 -Wall -Wextra -Wno-unused-parameter -Wno-parentheses -Wno-long-long -Wno-missing-field-initializers -Wno-tautological-compare -Wno-parentheses-equality -Wno-constant-logical-operand -Wno-self-assign -Wunused-variable -Wimplicit-int -Wpointer-arith -Wwrite-strings -Wdeclaration-after-statement -Wimplicit-function-declaration -Wdeprecated-declarations -Wno-packed-bitfield-compat -Wsuggest-attribute=noreturn -Wsuggest-attribute=format
target_alias =
host_alias = x86_64-redhat-linux-gnu
build_alias = x86_64-redhat-linux-gnu
ECHO_T =
ECHO_N = -n
ECHO_C =
DEFS =
mandir = /opt/rh/rh-ruby25/root/usr/share/man
localedir = /opt/rh/rh-ruby25/root/usr/share/locale
psdir = /opt/rh/rh-ruby25/root/usr/share/doc/ruby
pdfdir = /opt/rh/rh-ruby25/root/usr/share/doc/ruby
dvidir = /opt/rh/rh-ruby25/root/usr/share/doc/ruby
htmldir = /opt/rh/rh-ruby25/root/usr/share/doc/ruby
infodir = /opt/rh/rh-ruby25/root/usr/share/info
docdir = /opt/rh/rh-ruby25/root/usr/share/doc/ruby
oldincludedir = /usr/include
localstatedir = /var/opt/rh/rh-ruby25
sharedstatedir = /var/opt/rh/rh-ruby25/lib
sysconfdir = /etc/opt/rh/rh-ruby25
datadir = /opt/rh/rh-ruby25/root/usr/share
datarootdir = /opt/rh/rh-ruby25/root/usr/share
libexecdir = /opt/rh/rh-ruby25/root/usr/libexec
sbindir = /opt/rh/rh-ruby25/root/usr/sbin
bindir = /opt/rh/rh-ruby25/root/usr/bin
exec_prefix = /opt/rh/rh-ruby25/root/usr
PACKAGE_URL =
PACKAGE_BUGREPORT =
PACKAGE_STRING =
PACKAGE_VERSION =
PACKAGE_TARNAME =
PACKAGE_NAME =
PATH_SEPARATOR = :
SHELL = /bin/sh
UNICODE_VERSION = 10.0.0
topdir = /opt/rh/rh-ruby25/root/usr/lib64/ruby
Activated Ruby gems
did_you_mean => 1.2.0
Ruby load path ($LOAD_PATH)
/opt/rh/rh-ruby25/root/usr/share/gems/gems/did_you_mean-1.2.0/lib
Ruby loaded libraries ($LOADED_FEATURES)
enumerator.so
thread.rb
rational.so
complex.so
/opt/rh/rh-ruby25/root/usr/lib64/ruby/enc/encdb.so
/opt/rh/rh-ruby25/root/usr/lib64/ruby/enc/trans/transdb.so
/opt/rh/rh-ruby25/root/usr/lib64/ruby/rbconfig.rb
/opt/rh/rh-ruby25/root/usr/share/rubygems/rubygems/compatibility.rb
/opt/rh/rh-ruby25/root/usr/share/rubygems/rubygems/defaults.rb
/opt/rh/rh-ruby25/root/usr/share/rubygems/rubygems/deprecate.rb
/opt/rh/rh-ruby25/root/usr/share/rubygems/rubygems/errors.rb
/opt/rh/rh-ruby25/root/usr/share/rubygems/rubygems/version.rb
/opt/rh/rh-ruby25/root/usr/share/rubygems/rubygems/requirement.rb
/opt/rh/rh-ruby25/root/usr/share/rubygems/rubygems/platform.rb
/opt/rh/rh-ruby25/root/usr/share/rubygems/rubygems/basic_specification.rb
/opt/rh/rh-ruby25/root/usr/share/rubygems/rubygems/stub_specification.rb
/opt/rh/rh-ruby25/root/usr/share/rubygems/rubygems/util/list.rb
/opt/rh/rh-ruby25/root/usr/lib64/ruby/stringio.so
/opt/rh/rh-ruby25/root/usr/share/ruby/uri/rfc2396_parser.rb
/opt/rh/rh-ruby25/root/usr/share/ruby/uri/rfc3986_parser.rb
/opt/rh/rh-ruby25/root/usr/share/ruby/uri/common.rb
/opt/rh/rh-ruby25/root/usr/share/ruby/uri/generic.rb
/opt/rh/rh-ruby25/root/usr/share/ruby/uri/ftp.rb
/opt/rh/rh-ruby25/root/usr/share/ruby/uri/http.rb
/opt/rh/rh-ruby25/root/usr/share/ruby/uri/https.rb
/opt/rh/rh-ruby25/root/usr/share/ruby/uri/ldap.rb
/opt/rh/rh-ruby25/root/usr/share/ruby/uri/ldaps.rb
/opt/rh/rh-ruby25/root/usr/share/ruby/uri/mailto.rb
/opt/rh/rh-ruby25/root/usr/share/ruby/uri.rb
/opt/rh/rh-ruby25/root/usr/share/rubygems/rubygems/specification.rb
/opt/rh/rh-ruby25/root/usr/share/rubygems/rubygems/exceptions.rb
/opt/rh/rh-ruby25/root/usr/share/rubygems/rubygems/defaults/operating_system.rb
/opt/rh/rh-ruby25/root/usr/share/rubygems/rubygems/core_ext/kernel_gem.rb
/opt/rh/rh-ruby25/root/usr/share/ruby/monitor.rb
/opt/rh/rh-ruby25/root/usr/share/rubygems/rubygems/core_ext/kernel_require.rb
/opt/rh/rh-ruby25/root/usr/share/rubygems/rubygems.rb
/opt/rh/rh-ruby25/root/usr/share/rubygems/rubygems/dependency.rb
/opt/rh/rh-ruby25/root/usr/share/rubygems/rubygems/path_support.rb
/opt/rh/rh-ruby25/root/usr/share/gems/gems/did_you_mean-1.2.0/lib/did_you_mean/version.rb
/opt/rh/rh-ruby25/root/usr/share/gems/gems/did_you_mean-1.2.0/lib/did_you_mean/core_ext/name_error.rb
/opt/rh/rh-ruby25/root/usr/share/gems/gems/did_you_mean-1.2.0/lib/did_you_mean/levenshtein.rb
/opt/rh/rh-ruby25/root/usr/share/gems/gems/did_you_mean-1.2.0/lib/did_you_mean/jaro_winkler.rb
/opt/rh/rh-ruby25/root/usr/share/gems/gems/did_you_mean-1.2.0/lib/did_you_mean/spell_checker.rb
/opt/rh/rh-ruby25/root/usr/share/ruby/delegate.rb
/opt/rh/rh-ruby25/root/usr/share/gems/gems/did_you_mean-1.2.0/lib/did_you_mean/spell_checkers/name_error_checkers/class_name_checker.rb
/opt/rh/rh-ruby25/root/usr/share/gems/gems/did_you_mean-1.2.0/lib/did_you_mean/spell_checkers/name_error_checkers/variable_name_checker.rb
/opt/rh/rh-ruby25/root/usr/share/gems/gems/did_you_mean-1.2.0/lib/did_you_mean/spell_checkers/name_error_checkers.rb
/opt/rh/rh-ruby25/root/usr/share/gems/gems/did_you_mean-1.2.0/lib/did_you_mean/spell_checkers/method_name_checker.rb
/opt/rh/rh-ruby25/root/usr/share/gems/gems/did_you_mean-1.2.0/lib/did_you_mean/spell_checkers/key_error_checker.rb
/opt/rh/rh-ruby25/root/usr/share/gems/gems/did_you_mean-1.2.0/lib/did_you_mean/spell_checkers/null_checker.rb
/opt/rh/rh-ruby25/root/usr/share/gems/gems/did_you_mean-1.2.0/lib/did_you_mean/formatters/plain_formatter.rb
/opt/rh/rh-ruby25/root/usr/share/gems/gems/did_you_mean-1.2.0/lib/did_you_mean.rb
/opt/rh/rh-ruby25/root/usr/share/rubygems/rubygems/bundler_version_finder.rb
/opt/rh/rh-ruby25/root/usr/share/rubygems/rubygems/util.rb
/usr/share/passenger/phusion_passenger.rb
/opt/rh/rh-ruby25/root/usr/lib64/ruby/etc.so
/opt/rh/rh-ruby25/root/usr/share/ruby/fileutils.rb
/opt/rh/rh-ruby25/root/usr/share/ruby/tmpdir.rb
/usr/share/passenger/phusion_passenger/utils/tmpio.rb
/usr/share/passenger/phusion_passenger/platform_info.rb
/usr/share/passenger/phusion_passenger/platform_info/operating_system.rb
/usr/share/passenger/phusion_passenger/platform_info/ruby.rb
/usr/share/passenger/phusion_passenger/platform_info/binary_compatibility.rb
/usr/share/passenger/phusion_passenger/constants.rb
/usr/share/passenger/phusion_passenger/native_support.rb
/opt/rh/rh-ruby25/root/usr/lib64/ruby/socket.so
/opt/rh/rh-ruby25/root/usr/lib64/ruby/io/wait.so
/opt/rh/rh-ruby25/root/usr/share/ruby/socket.rb
/usr/share/passenger/phusion_passenger/ruby_core_enhancements.rb
/usr/share/passenger/phusion_passenger/utils/tmpdir.rb
/usr/share/passenger/phusion_passenger/utils.rb
/usr/share/passenger/phusion_passenger/preloader_shared_helpers.rb
/usr/share/passenger/phusion_passenger/public_api.rb
/usr/share/passenger/phusion_passenger/debug_logging.rb
/opt/rh/rh-ruby25/root/usr/share/ruby/shellwords.rb
/usr/share/passenger/phusion_passenger/utils/shellwords.rb
/usr/share/passenger/phusion_passenger/loader_shared_helpers.rb
/opt/rh/rh-ruby25/root/usr/lib64/ruby/fcntl.so
/usr/share/passenger/phusion_passenger/message_channel.rb
/usr/share/passenger/phusion_passenger/message_client.rb
/usr/share/passenger/phusion_passenger/utils/native_support_utils.rb
/usr/share/passenger/phusion_passenger/utils/unseekable_socket.rb
/usr/share/passenger/phusion_passenger/request_handler/thread_handler.rb
/usr/share/passenger/phusion_passenger/request_handler.rb
/usr/share/passenger/phusion_passenger/utils/tee_input.rb
/usr/share/passenger/phusion_passenger/rack/thread_handler_extension.rb
Powered by Phusion Passenger, mod_rails / mod_rack for Apache and Nginx.
Foreman and Proxy versions:nightly
Katello version: nightly
Please help me
Thanks
Laxman
