Hi at all,
I'm new to Foreman/Katello and I'm testing different configurations using a
VM and snapshots to start over. In one of my first tests, I have been able
to configure an HostGroup and get a PXE entry for it. Now, I'm not able to
get it anymore.
I'm using Katello 2.4.0 / Foreman 1.10.1, my foreman-proxy/katello-capsule
does not provide dns or dhcp but only TFTP/PXE, but this should't be a
problem.
If I create an Host, its TFTP entry has been created, if I put the same
setting in an Host Group, and then click on 'Build PXE default' under Host
-> Provisionig Template, I found a 'default' file in my
'/var/lib/tftpboot/pxelinux.cfg/' but it contain only 'local' and
'discovery' entry. I've enabled debug on foreman and foreman-proxy but only
error (???) message is
> Started GET "/provisioning_templates/build_pxe_default" for
147.122.24.46 at 2016-02-26 18:35:44 +0100
2016-02-26 18:35:44 [app] [I] Processing by
ProvisioningTemplatesController#build_pxe_default as HTML
2016-02-26 18:35:44 [app] [D] Setting current user thread-local variable to
Admin User
2016-02-26 18:35:44 [app] [D] Setting current organization thread-local
variable to MyORG
2016-02-26 18:35:44 [app] [D] Setting current location thread-local
variable to MySITE
2016-02-26 18:35:44 [app] [I] Redirected to
https://katello.sissa.it/templates/provisioning_templates?page=3
2016-02-26 18:35:44 [app] [I] Completed 302 Found in 162ms (ActiveRecord:
10.5ms)
I think it is a error message for the 302 code (but I'm not sure).
I' ve configured:
- a subnet
- a domain
- a partition table
- an operating system and an installation media
I'm using 'production' Puppet environment (but I have no classes) and
'Library' lifecycle environment (but without activation keys). I'm also
able to get the provisioning template using the URL
https://katello.sissa.it/unattended/template/PROVISIONING_TEMPLATE/HOST_GROUP,
but Foreman does not create an HostGroup entry in its TFTP default file.
Any clue ? I'm sure I'm forgetting something, but I don't know what …
Cheers
