[katello] Problem Syncing Capsule
Hi all,
After successfully creating a katello 2.0 capsule (on CentOS 6.6), I am
unable to synchronize content. I've ensured the capsule has an environment
attached and I've recently published new content. However, whenever I
either publish content or manually sync from hammer, I get the following
error. Any ideas would be appreciated.
RestClient::InternalServerError: 500 Internal Server Error
Backtrace:
/opt/rh/ruby193/root/usr/share/gems/gems/rest-client-1.6.7/lib/restclient/abstract_response.rb:48:in return!' /opt/rh/ruby193/root/usr/share/gems/gems/runcible-1.1.0/lib/runcible/base.rb:97:inblock in get_response'
/opt/rh/ruby193/root/usr/share/gems/gems/rest-client-1.6.7/lib/restclient/request.rb:228:in call' /opt/rh/ruby193/root/usr/share/gems/gems/rest-client-1.6.7/lib/restclient/request.rb:228:inprocess_result'
/opt/rh/ruby193/root/usr/share/gems/gems/rbovirt-0.0.29/lib/restclient_ext/request.rb:50:in block in transmit' /opt/rh/ruby193/root/usr/share/ruby/net/http.rb:746:instart'
/opt/rh/ruby193/root/usr/share/gems/gems/rbovirt-0.0.29/lib/restclient_ext/request.rb:44:in transmit' /opt/rh/ruby193/root/usr/share/gems/gems/rest-client-1.6.7/lib/restclient/request.rb:64:inexecute'
/opt/rh/ruby193/root/usr/share/gems/gems/rest-client-1.6.7/lib/restclient/request.rb:33:in execute' /opt/rh/ruby193/root/usr/share/gems/gems/rest-client-1.6.7/lib/restclient/resource.rb:67:inpost'
/opt/rh/ruby193/root/usr/share/gems/gems/runcible-1.1.0/lib/runcible/base.rb:96:in get_response' /opt/rh/ruby193/root/usr/share/gems/gems/runcible-1.1.0/lib/runcible/base.rb:87:incall'
/opt/rh/ruby193/root/usr/share/gems/gems/runcible-1.1.0/lib/runcible/resources/consumer.rb:152:in update_units' /opt/rh/ruby193/root/usr/share/gems/gems/runcible-1.1.0/lib/runcible/extensions/consumer.rb:96:inupdate_content'
/opt/rh/ruby193/root/usr/share/gems/gems/katello-2.0.0/app/lib/actions/pulp/consumer/sync_node.rb:26:in invoke_external_task' /opt/rh/ruby193/root/usr/share/gems/gems/dynflow-0.7.3/lib/dynflow/action/polling.rb:70:ininitiate_external_action'
/opt/rh/ruby193/root/usr/share/gems/gems/dynflow-0.7.3/lib/dynflow/action/polling.rb:12:in run' /opt/rh/ruby193/root/usr/share/gems/gems/dynflow-0.7.3/lib/dynflow/action/cancellable.rb:9:inrun'
/opt/rh/ruby193/root/usr/share/gems/gems/katello-2.0.0/app/lib/actions/pulp/abstract_async_task.rb:57:in run' /opt/rh/ruby193/root/usr/share/gems/gems/dynflow-0.7.3/lib/dynflow/action.rb:443:inblock (3 levels) in execute_run'
/opt/rh/ruby193/root/usr/share/gems/gems/dynflow-0.7.3/lib/dynflow/middleware/stack.rb:26:in call' /opt/rh/ruby193/root/usr/share/gems/gems/dynflow-0.7.3/lib/dynflow/middleware/stack.rb:26:inpass'
/opt/rh/ruby193/root/usr/share/gems/gems/dynflow-0.7.3/lib/dynflow/middleware.rb:16:in pass' /opt/rh/ruby193/root/usr/share/gems/gems/katello-2.0.0/app/lib/actions/middleware/remote_action.rb:28:inblock in run'
/opt/rh/ruby193/root/usr/share/gems/gems/katello-2.0.0/app/lib/actions/middleware/remote_action.rb:58:in block (2 levels) in as_remote_user' /opt/rh/ruby193/root/usr/share/gems/gems/katello-2.0.0/app/lib/katello/util/thread_session.rb:85:inset_pulp_config'
/opt/rh/ruby193/root/usr/share/gems/gems/katello-2.0.0/app/lib/actions/middleware/remote_action.rb:44:in as_pulp_user' /opt/rh/ruby193/root/usr/share/gems/gems/katello-2.0.0/app/lib/actions/middleware/remote_action.rb:57:inblock in as_remote_user'
/opt/rh/ruby193/root/usr/share/gems/gems/katello-2.0.0/app/lib/katello/util/thread_session.rb:92:in set_cp_config' /opt/rh/ruby193/root/usr/share/gems/gems/katello-2.0.0/app/lib/actions/middleware/remote_action.rb:39:inas_cp_user'
/opt/rh/ruby193/root/usr/share/gems/gems/katello-2.0.0/app/lib/actions/middleware/remote_action.rb:56:in as_remote_user' /opt/rh/ruby193/root/usr/share/gems/gems/katello-2.0.0/app/lib/actions/middleware/remote_action.rb:28:inrun'
/opt/rh/ruby193/root/usr/share/gems/gems/dynflow-0.7.3/lib/dynflow/middleware/stack.rb:22:in call' /opt/rh/ruby193/root/usr/share/gems/gems/dynflow-0.7.3/lib/dynflow/middleware/stack.rb:26:inpass'
/opt/rh/ruby193/root/usr/share/gems/gems/dynflow-0.7.3/lib/dynflow/middleware.rb:16:in pass' /opt/rh/ruby193/root/usr/share/gems/gems/dynflow-0.7.3/lib/dynflow/action/progress.rb:30:inwith_progress_calculation'
/opt/rh/ruby193/root/usr/share/gems/gems/dynflow-0.7.3/lib/dynflow/action/progress.rb:16:in run' /opt/rh/ruby193/root/usr/share/gems/gems/dynflow-0.7.3/lib/dynflow/middleware/stack.rb:22:incall'
/opt/rh/ruby193/root/usr/share/gems/gems/dynflow-0.7.3/lib/dynflow/middleware/stack.rb:26:in pass' /opt/rh/ruby193/root/usr/share/gems/gems/dynflow-0.7.3/lib/dynflow/middleware.rb:16:inpass'
/opt/rh/ruby193/root/usr/share/gems/gems/katello-2.0.0/app/lib/actions/middleware/keep_locale.rb:24:in block in run' /opt/rh/ruby193/root/usr/share/gems/gems/katello-2.0.0/app/lib/actions/middleware/keep_locale.rb:35:inwith_locale'
/opt/rh/ruby193/root/usr/share/gems/gems/katello-2.0.0/app/lib/actions/middleware/keep_locale.rb:24:in run' /opt/rh/ruby193/root/usr/share/gems/gems/dynflow-0.7.3/lib/dynflow/middleware/stack.rb:22:incall'
/opt/rh/ruby193/root/usr/share/gems/gems/dynflow-0.7.3/lib/dynflow/middleware/world.rb:30:in execute' /opt/rh/ruby193/root/usr/share/gems/gems/dynflow-0.7.3/lib/dynflow/action.rb:442:inblock (2 levels) in execute_run'
/opt/rh/ruby193/root/usr/share/gems/gems/dynflow-0.7.3/lib/dynflow/action.rb:441:in catch' /opt/rh/ruby193/root/usr/share/gems/gems/dynflow-0.7.3/lib/dynflow/action.rb:441:inblock in execute_run'
/opt/rh/ruby193/root/usr/share/gems/gems/dynflow-0.7.3/lib/dynflow/action.rb:365:in call' /opt/rh/ruby193/root/usr/share/gems/gems/dynflow-0.7.3/lib/dynflow/action.rb:365:inblock in with_error_handling'
/opt/rh/ruby193/root/usr/share/gems/gems/dynflow-0.7.3/lib/dynflow/action.rb:365:in catch' /opt/rh/ruby193/root/usr/share/gems/gems/dynflow-0.7.3/lib/dynflow/action.rb:365:inwith_error_handling'
/opt/rh/ruby193/root/usr/share/gems/gems/dynflow-0.7.3/lib/dynflow/action.rb:436:in execute_run' /opt/rh/ruby193/root/usr/share/gems/gems/dynflow-0.7.3/lib/dynflow/action.rb:230:inexecute'
/opt/rh/ruby193/root/usr/share/gems/gems/dynflow-0.7.3/lib/dynflow/execution_plan/steps/abstract_flow_step.rb:9:in block (2 levels) in execute' /opt/rh/ruby193/root/usr/share/gems/gems/dynflow-0.7.3/lib/dynflow/execution_plan/steps/abstract.rb:152:incall'
/opt/rh/ruby193/root/usr/share/gems/gems/dynflow-0.7.3/lib/dynflow/execution_plan/steps/abstract.rb:152:in with_meta_calculation' /opt/rh/ruby193/root/usr/share/gems/gems/dynflow-0.7.3/lib/dynflow/execution_plan/steps/abstract_flow_step.rb:8:inblock in execute'
/opt/rh/ruby193/root/usr/share/gems/gems/dynflow-0.7.3/lib/dynflow/execution_plan/steps/abstract_flow_step.rb:22:in open_action' /opt/rh/ruby193/root/usr/share/gems/gems/dynflow-0.7.3/lib/dynflow/execution_plan/steps/abstract_flow_step.rb:7:inexecute'
/opt/rh/ruby193/root/usr/share/gems/gems/dynflow-0.7.3/lib/dynflow/executors/parallel/worker.rb:20:in block in on_message' /opt/rh/ruby193/root/usr/share/gems/gems/algebrick-0.4.0/lib/algebrick.rb:859:inblock in assigns'
/opt/rh/ruby193/root/usr/share/gems/gems/algebrick-0.4.0/lib/algebrick.rb:858:in tap' /opt/rh/ruby193/root/usr/share/gems/gems/algebrick-0.4.0/lib/algebrick.rb:858:inassigns'
/opt/rh/ruby193/root/usr/share/gems/gems/algebrick-0.4.0/lib/algebrick.rb:138:in match_value' /opt/rh/ruby193/root/usr/share/gems/gems/algebrick-0.4.0/lib/algebrick.rb:116:inblock in match'
/opt/rh/ruby193/root/usr/share/gems/gems/algebrick-0.4.0/lib/algebrick.rb:115:in each' /opt/rh/ruby193/root/usr/share/gems/gems/algebrick-0.4.0/lib/algebrick.rb:115:inmatch'
/opt/rh/ruby193/root/usr/share/gems/gems/dynflow-0.7.3/lib/dynflow/executors/parallel/worker.rb:17:in on_message' /opt/rh/ruby193/root/usr/share/gems/gems/dynflow-0.7.3/lib/dynflow/micro_actor.rb:82:inon_envelope'
/opt/rh/ruby193/root/usr/share/gems/gems/dynflow-0.7.3/lib/dynflow/micro_actor.rb:72:in receive' /opt/rh/ruby193/root/usr/share/gems/gems/dynflow-0.7.3/lib/dynflow/micro_actor.rb:99:inblock (2 levels) in run'
/opt/rh/ruby193/root/usr/share/gems/gems/dynflow-0.7.3/lib/dynflow/micro_actor.rb:99:in loop' /opt/rh/ruby193/root/usr/share/gems/gems/dynflow-0.7.3/lib/dynflow/micro_actor.rb:99:inblock in run'
/opt/rh/ruby193/root/usr/share/gems/gems/dynflow-0.7.3/lib/dynflow/micro_actor.rb:99:in catch' /opt/rh/ruby193/root/usr/share/gems/gems/dynflow-0.7.3/lib/dynflow/micro_actor.rb:99:inrun'
/opt/rh/ruby193/root/usr/share/gems/gems/dynflow-0.7.3/lib/dynflow/micro_actor.rb:13:in block in initialize' /opt/rh/ruby193/root/usr/share/gems/gems/logging-1.8.1/lib/logging/diagnostic_context.rb:323:incall'
/opt/rh/ruby193/root/usr/share/gems/gems/logging-1.8.1/lib/logging/diagnostic_context.rb:323:in `block in create_with_logging_context'
