[Katello] problem with capsule installation
Hi Everyone,
I am unable to install the capsule that was create on the Master is in
another datacenter.
I used the Katello Capsule Docs from katello.org.
I have create the file from the master and scp the file to the capsule.
The capsule-installer error with the following log file.
capsule-installer.3.log
[DEBUG 2014-12-01 19:34:40 main] Loading hook
/usr/share/katello-installer/hooks/boot/10-reset_hook.rb [DEBUG 2014-12-01
/usr/share/katello-installer/hooks/boot/11-clear_pulp_data_hook.rb [DEBUG
/usr/share/katello-installer/hooks/boot/12-clear_puppet_environments.rb
/usr/share/katello-installer/hooks/boot/20-certs_update.rb [DEBUG
/usr/share/katello-installer/hooks/pre/10-reset_feature.rb [DEBUG
/usr/share/katello-installer/hooks/pre/11-clear_pulp_data_feature.rb [DEBUG
/usr/share/katello-installer/hooks/pre/12-clear_puppet_environments_feature.rb
/usr/share/katello-installer/hooks/pre/15-check_java.rb [DEBUG 2014-12-01
/usr/share/katello-installer/hooks/pre/20-certs_update.rb [DEBUG 2014-12-01
/usr/share/katello-installer/hooks/post/10-post_install.rb [DEBUG
/usr/share/katello-installer/hooks/pre_validations/10-check_capsule_pulp.rb
[ INFO 2014-12-01 19:34:40 main] Executing hooks in group boot [DEBUG
2014-12-01 19:34:40 main] Hook
/usr/share/katello-installer/hooks/boot/10-reset_hook.rb returned
#<Clamp::Option::Definition:0x7f eec048fb28 @type=:flag,
@switches=["–reset"], @description="This option will drop the Katello
database and clear all subsequent backend data stores.You will lose all
data! Unfortunately we\ncan't detect a failure at the moment so you should
verify the success\nmanually. e.g. dropping can fail when DB is currently
in use.", @default_value=false, @attribute_name="reset", @multivalued=nil>
[DEBUG 2014-12-01 19:34:40 main] Hook
/usr/share/katello-installer/hooks/boot/20-certs_update.rb returned
#<Clamp::Option::Definition:0x 7feec042f4a8 @type=:flag,
@switches=["–certs-update-all"], @description="This option will enforce an
update of all the certificates for given host", @default_value=false,
@attribute_name="certs_update_all", @multivalued=nil> [DEBUG 2014-12-01
19:34:40 main] Hook
returned #<Clamp::Option:: Definition:0x7feec0423810 @type=:flag,
@switches=["–clear-puppet-environments"], @description="This option will
clear all Puppet enviro nments from disk located in
'/etc/puppet/environments/'.", @default_value=false,
@attribute_name="clear_puppet_environments", @multivalu ed=nil> [DEBUG
/usr/share/katello-installer/hooks/boot/11-clear_pulp_data_hook.rb returned
#<Clamp::Option::Defin ition:0x7feec0411598 @type=:flag,
@switches=["–clear-pulp-content"], @description="This option will clear
all Pulp content from disk lo cated in '/var/lib/pulp/content/'.",
@default_value=false, @attribute_name="clear_pulp_content",
@multivalued=nil> [ INFO 2014-12-01 19:34:40 main] All hooks in group boot
finished [ INFO 2014-12-01 19:34:40 main] Executing hooks in group init [
INFO 2014-12-01 19:34:40 main] All hooks in group init finished [DEBUG
2014-12-01 19:34:40 main] Creating tmp dir within /etc/katello-installer…
[ INFO 2014-12-01 19:34:40 main] Parsing default values from puppet
modules… [DEBUG 2014-12-01 19:34:40 main] checking presence of
/usr/share/katello-installer/modules/certs/manifests/params.pp [DEBUG
/usr/share/katello-installer/modules/capsule/manifests/params.pp [DEBUG
2014-12-01 19:34:40 main] echo
'$kafo_config_file="/etc/katello-installer/capsule-installer.yaml"
$kafo_add_progress=true $temp_
dir="/etc/katello-installer/d20141201-21374-l4a5ve" include certs::params
include capsule::params dump_values("certs::params::org","cert
s::params::expiration","certs::params::group","certs::params::server_ca_cert","certs::params::user","certs::params::ssl_build_dir","cert
s::params::deploy","certs::params::server_cert","certs::params::log_dir","certs::params::org_unit","certs::params::ca_expiration","certs
::params::password_file_dir","certs::params::server_ca_name","certs::params::pki_dir","certs::params::generate","certs::params::regenera
te_ca","certs::params::city","certs::params::server_cert_req","certs::params::node_fqdn","certs::params::regenerate","certs::params::ca_
common_name","certs::params::country","certs::params::state","certs::params::server_key","certs::params::default_ca_name","capsule::para
ms::tftp_root","capsule::params::dhcp_interface","capsule::params::dns_zone","capsule::params::realm","capsule::params::realm_principal"
,"capsule::params::pulp_oauth_effective_user","capsule::params::dhcp_gateway","capsule::params::dns_server","capsule::params::foreman_oa
uth_secret","capsule::params::realm_provider","capsule::params::pulp",capsule::params::foreman_proxy_port,"capsule::params::puppetca","c
apsule::params::dhcp_nameservers","capsule::params::dns","capsule::params::puppet","capsule::params::tftp_servername","capsule::params::
dhcp_range","capsule::params::dns_provider","capsule::params::dns_tsig_keytab","capsule::params::foreman_oauth_key","capsule::params::tf
tp_syslinux_root","capsule::params::dns_tsig_principal",capsule::params::dns_forwarders,"capsule::params::dhcp_key_secret","capsule::par
ams::dns_interface","capsule::params::freeipa_remove_dns","capsule::params::foreman_oauth_effective_user",capsule::params::tftp_dirs,"ca
psule::params::dhcp_leases","capsule::params::dns_managed","capsule::params::certs_tar","capsule::params::dhcp","capsule::params::pulp_m
aster","capsule::params::pulp_oauth_secret","capsule::params::tftp","capsule::params::dhcp_managed","capsule::params::dhcp_config","caps
ule::params::parent_fqdn","capsule::params::pulp_admin_password","capsule::params::pulp_oauth_key",capsule::params::tftp_syslinux_files,
"capsule::params::dhcp_vendor","capsule::params::dhcp_key_name","capsule::params::dns_reverse","capsule::params::dns_ttl","capsule::para
ms::virsh_network","capsule::params::realm_keytab","capsule::params::register_in_foreman")'
> RUBYLIB=/usr/lib/ruby/gems/1.8/gems/kafo-0 .6.5/lib/kafo/…/…//modules:
puppet apply --modulepath
/usr/share/katello-installer/modules:/usr/lib/ruby/gems/1.8/gems/kafo-0.6.5/modu
les 2>&1 [DEBUG 2014-12-01 19:34:40 main] Warning: Setting config_version
is deprecated in puppet.conf. See http://links.puppetlabs.com/env
-settings-deprecations
<http://links.puppetlabs.com/env-settings-deprecations> (at
/usr/lib/ruby/site_ruby/1.8/puppet/settings.rb:1141:in
`issue_deprecation_warning') Notice: Compiled catalog for
pco-vm-swk6-11.aircell.prod in environment production in 0.97 seconds
Notice: Finished catalog run in 0.10 seconds [ INFO 2014-12-01 19:34:40
main] … finished [ INFO 2014-12-01 19:34:40 main] Executing hooks in
group pre_values [ INFO 2014-12-01 19:34:40 main] All hooks in group
pre_values finished [ INFO 2014-12-01 19:34:40 main] Executing hooks in
group pre_validations [ERROR 2014-12-01 19:34:40 main] the pulp node can't
be installed on a machine with Katello master [DEBUG 2014-12-01 19:34:40
main] Exit with status code: 101 (signal was 101) [ERROR 2014-12-01
19:34:40 main] Repeating errors encountered during run: [ERROR 2014-12-01
19:34:40 main] the pulp node can't be installed on a machine with Katello
master [DEBUG 2014-12-01 19:34:40 main] Cleaning
/etc/katello-installer/d20141201-21374-l4a5ve [DEBUG 2014-12-01 19:34:40
main] Cleaning /tmp/default_values.yaml
Thanks Al Johnson
> Hi Everyone,
> another datacenter.
[snip]
> main]
You shouldn't install the 'katello' package itself on a capsule, this looks like
the problem.
··· On Mon, Dec 08, 2014 at 12:58:53PM -0600, Alvin Johnson wrote:
Stephen Benjamin
Red Hat GmbH | http://de.redhat.com/ | Sitz: Grasbrunn
Handelsregister: Amtsgericht München, HRB 153243
Geschäftsführer: Charles Cachera, Michael Cunningham,
Michael O’Neill, Charles Peters
