Hello.
I'm currently trying out katello for provisioning and config management
I have successfully been able to provisioning new hosts, but the puppet
agent doesn't get installed,
any pointer in a direction to what I'm missing?
the provisioning template look like this:
install
url --url
http://foreman.somedomain.com/pulp/repos/Default_Organization/Library/custom/CentOS_7_2_uninett/x86_64/
lang en_US.UTF-8
selinux --enforcing
keyboard us
skipx
network --bootproto dhcp --hostname mac1866da6b5507.foreman.somedomain.com
–device=18:66:da:6b:55:07
rootpw --iscrypted $5$F8PB/F4r$SMMmuT5fdXxnGQIEw0YwUecYtM9FLPW6FaEw5K6BcAT1
firewall --service=ssh
authconfig --useshadow --passalgo=sha256 --kickstart
timezone --utc UTC
bootloader --location=mbr --append="nofb quiet splash=quiet"
zerombr
clearpart --all --initlabel
autopart
text
reboot
%packages --ignoremissing
yum
dhclient
ntp
wget
@Core
%end
%post --nochroot
exec < /dev/tty3 > /dev/tty3
#changing to VT 3 so that we can see whats going on…
/usr/bin/chvt 3
cp -va /etc/resolv.conf /mnt/sysimage/etc/resolv.conf
/usr/bin/chvt 1
) 2>&1 | tee /mnt/sysimage/root/install.postnochroot.log
%end
%post
logger "Starting anaconda mac1866da6b5507.foreman.somedomain.com
postinstall"
/usr/bin/chvt 3
eno3 interface
real=ip -o link | grep 18:66:da:6b:55:07 | awk '{print $2;}' | sed s/:$//
ifcfg files are ignored by NM if their name contains colons so we convert
colons to underscore
sanitized_real=$real
cat << EOF > /etc/sysconfig/network-scripts/ifcfg-$sanitized_real
BOOTPROTO="dhcp"
DEVICE=$real
HWADDR="18:66:da:6b:55:07"
ONBOOT=yes
PEERDNS=yes
PEERROUTES=yes
EOF
#update local time
echo "updating system time"
/usr/sbin/ntpdate -sub 0.fedora.pool.ntp.org
/usr/sbin/hwclock --systohc
update all the base packages from the updates repository
yum -t -y -e 0 update
SSH keys setup snippet for Remote Execution plugin
# # Parameters: # # remote_execution_ssh_keys: public keys to be put in ~/.ssh/authorized_keys # # remote_execution_ssh_user: user for which remote_execution_ssh_keys will be # authorized # # This template sets up SSH keys in any host so that as long as your public # SSH key is in remote_execution_ssh_keys, you can SSH into a host. This only # works in combination with Remote Execution plugin.A personal recomendation: create a global parameter
and put your keys there, so that you can access any newly provisioned host
without having to set up the parameter on every host or host group.
sync
Inform the build system that we are done.
echo "Informing Foreman that we are built"
wget -q -O /dev/null --no-check-certificate
http://foreman.somedomain.com/unattended/built
) 2>&1 | tee /root/install.post.log
exit 0
%end
