/opt/rh/ruby193/root/usr/share/gems/gems/runcible-1.3.1/lib/runcible/extensions/repository.rb:151:in block in rpm_ids'- /opt/rh/ruby193/root/usr/share/gems/gems/runcible-1.3.1/lib/runcible/extensions/repository.rb:139:in<<'
`block (2 levels) in rpm_ids'
/opt/rh/ruby193/root/usr/share/gems/gems/runcible-1.3.1/lib/runcible/extensions/repository.rb:138:in loop'- /opt/rh/ruby193/root/usr/share/gems/gems/runcible-1.3.1/lib/runcible/extensions/repository.rb:138:inblock in rpm_ids'
/opt/rh/ruby193/root/usr/share/gems/gems/katello-2.2.0/app/lib/actions/middleware/remote_action.rb:28:in block in run'- /opt/rh/ruby193/root/usr/share/gems/gems/katello-2.2.0/app/lib/actions/middleware/remote_action.rb:58:inblock (2 levels) in as_remote_user'
/opt/rh/ruby193/root/usr/share/gems/gems/katello-2.2.0/app/lib/actions/middleware/remote_action.rb:44:in as_pulp_user'- /opt/rh/ruby193/root/usr/share/gems/gems/katello-2.2.0/app/lib/actions/middleware/remote_action.rb:57:inblock in as_remote_user'
/opt/rh/ruby193/root/usr/share/gems/gems/dynflow-0.7.6/lib/dynflow/action.rb:454:in block in execute_run'- /opt/rh/ruby193/root/usr/share/gems/gems/dynflow-0.7.6/lib/dynflow/action.rb:371:incall'
`block in with_error_handling'
/opt/rh/ruby193/root/usr/share/gems/gems/dynflow-0.7.6/lib/dynflow/execution_plan/steps/abstract.rb:152:in with_meta_calculation'- /opt/rh/ruby193/root/usr/share/gems/gems/dynflow-0.7.6/lib/dynflow/execution_plan/steps/abstract_flow_step.rb:8:inblock in execute'
/opt/rh/ruby193/root/usr/share/gems/gems/dynflow-0.7.6/lib/dynflow/execution_plan/steps/abstract_flow_step.rb:7:in execute'- /opt/rh/ruby193/root/usr/share/gems/gems/dynflow-0.7.6/lib/dynflow/executors/parallel/worker.rb:20:inblock in on_message'
/opt/rh/ruby193/root/usr/share/gems/gems/algebrick-0.4.0/lib/algebrick.rb:859:in
`block in assigns'
/opt/rh/ruby193/root/usr/share/gems/gems/algebrick-0.4.0/lib/algebrick.rb:116:in block in match'- /opt/rh/ruby193/root/usr/share/gems/gems/algebrick-0.4.0/lib/algebrick.rb:115:ineach'
/opt/rh/ruby193/root/usr/share/gems/gems/dynflow-0.7.6/lib/dynflow/micro_actor.rb:13:in
`block in initialize'
/opt/rh/ruby193/root/usr/share/gems/gems/logging-1.8.1/lib/logging/diagnostic_context.rb:323:in call'- /opt/rh/ruby193/root/usr/share/gems/gems/logging-1.8.1/lib/logging/diagnostic_context.rb:323:inblock in create_with_logging_context'
/opt/rh/ruby193/root/usr/share/gems/gems/runcible-1.3.1/lib/runcible/extensions/repository.rb:151:in block in rpm_ids'- /opt/rh/ruby193/root/usr/share/gems/gems/runcible-1.3.1/lib/runcible/extensions/repository.rb:139:in<<’
`block (2 levels) in rpm_ids’
/opt/rh/ruby193/root/usr/share/gems/gems/runcible-1.3.1/lib/runcible/extensions/repository.rb:138:in loop'- /opt/rh/ruby193/root/usr/share/gems/gems/runcible-1.3.1/lib/runcible/extensions/repository.rb:138:inblock in rpm_ids’
/opt/rh/ruby193/root/usr/share/gems/gems/katello-2.2.0/app/lib/actions/middleware/remote_action.rb:28:in block in run'- /opt/rh/ruby193/root/usr/share/gems/gems/katello-2.2.0/app/lib/actions/middleware/remote_action.rb:58:inblock (2 levels) in as_remote_user’
/opt/rh/ruby193/root/usr/share/gems/gems/katello-2.2.0/app/lib/actions/middleware/remote_action.rb:44:in as_pulp_user'- /opt/rh/ruby193/root/usr/share/gems/gems/katello-2.2.0/app/lib/actions/middleware/remote_action.rb:57:inblock in as_remote_user’
/opt/rh/ruby193/root/usr/share/gems/gems/dynflow-0.7.6/lib/dynflow/action.rb:454:in block in execute_run'- /opt/rh/ruby193/root/usr/share/gems/gems/dynflow-0.7.6/lib/dynflow/action.rb:371:incall’
`block in with_error_handling’
/opt/rh/ruby193/root/usr/share/gems/gems/dynflow-0.7.6/lib/dynflow/execution_plan/steps/abstract.rb:152:in with_meta_calculation'- /opt/rh/ruby193/root/usr/share/gems/gems/dynflow-0.7.6/lib/dynflow/execution_plan/steps/abstract_flow_step.rb:8:inblock in execute’
/opt/rh/ruby193/root/usr/share/gems/gems/dynflow-0.7.6/lib/dynflow/execution_plan/steps/abstract_flow_step.rb:7:in execute'- /opt/rh/ruby193/root/usr/share/gems/gems/dynflow-0.7.6/lib/dynflow/executors/parallel/worker.rb:20:inblock in on_message’
`block in assigns’
/opt/rh/ruby193/root/usr/share/gems/gems/algebrick-0.4.0/lib/algebrick.rb:116:in block in match'- /opt/rh/ruby193/root/usr/share/gems/gems/algebrick-0.4.0/lib/algebrick.rb:115:ineach’
`block in initialize’
/opt/rh/ruby193/root/usr/share/gems/gems/logging-1.8.1/lib/logging/diagnostic_context.rb:323:in call'- /opt/rh/ruby193/root/usr/share/gems/gems/logging-1.8.1/lib/logging/diagnostic_context.rb:323:inblock in create_with_logging_context’
`block in assigns’
