Thank you Chris
It seems to be an issue with the SQL query : UPDATE "architectures" SET
"hosts_count" = COALESCE("hosts_count", 0) + 1 WHERE "architectures"."id" =
1
Waou, it takes 307s.
I also display the logs of candlepin, but found nothing else.
2016-04-22 09:35:43 [app] [I] Started POST
"/rhsm/consumers?owner=Default_Organization&activation_keys=my-key" for
172.17.0.126 at 2016-04-22 09:35:43 +0200
2016-04-22 09:35:43 [app] [I] Processing by
Katello::Api::Rhsm::CandlepinProxiesController#consumer_activate as JSON
2016-04-22 09:35:43 [app] [I] Parameters: {"facts"=>"[FILTERED]",
"contentTags"=>nil, "type"=>"system", "name"=>"a6f5bddaec84",
"owner"=>"Default_Organization", "activation_keys"=>"my-key"}
2016-04-22 09:35:44 [app] [I] Import facts for 'a6f5bddaec84' completed.
Added: 76, Updated: 0, Deleted 0 facts
2016-04-22 09:36:58,000 [thread=http-bio-8443-exec-10]
[req=a8b4f0c9-b4ff-4df1-96e3-204ec367bf31, org=] INFO
org.candlepin.common.filter.LoggingFilter - Request: verb=GET,
uri=/candlepin/activation_keys/8a80828f5418e6a50154190826db0009
2016-04-22 09:36:58,031 [thread=http-bio-8443-exec-10]
[req=a8b4f0c9-b4ff-4df1-96e3-204ec367bf31, org=Default_Organization] INFO
org.candlepin.common.filter.LoggingFilter - Response: status=200,
content-type="application/json", time=32
2016-04-22 09:36:58,130 [thread=http-bio-8443-exec-6]
[req=1218d92b-935f-4bc4-b627-aa92f07b2fdc, org=] INFO
uri=/candlepin/status
2016-04-22 09:36:58,135 [thread=http-bio-8443-exec-6]
content-type="application/json", time=4
2016-04-22 09:36:58,169 [thread=http-bio-8443-exec-5]
[req=9d4b4133-e96d-4bbd-aa35-42fea66f2df7, org=] INFO
2016-04-22 09:36:58,171 [thread=http-bio-8443-exec-5]
content-type="application/json", time=2
2016-04-22 09:36:58,253 [thread=http-bio-8443-exec-1]
[req=dbcd27ad-c7c2-44aa-95cd-3eabded76f23, org=] INFO
org.candlepin.common.filter.LoggingFilter - Request: verb=POST,
uri=/candlepin/environments/7-4/consumers/?activation_keys=9b2ef4c8-c8a7-4540-a379-f80a67012fbf
2016-04-22 09:37:00,124 [thread=http-bio-8443-exec-1]
org.candlepin.policy.js.autobind.AutobindRules - No pools available to
rules for products: []
org.candlepin.controller.CandlepinPoolManager - No entitlements available
for products: []
2016-04-22 09:37:00,133 [thread=http-bio-8443-exec-1]
org.candlepin.resource.ConsumerResource - Consumer
a3569c27-09e8-45a4-9285-aefe7029c9a5 created in org Default_Organization
2016-04-22 09:37:00,139 [thread=http-bio-8443-exec-1]
org.candlepin.audit.HornetqEventDispatcher - Sending event: Event
[id=null, target=CONSUMER, type=CREATED, time=Fri Apr 22 09:36:59 CEST
2016, entity=ff80808154398a2c01543ce67ab600a4]
2016-04-22 09:37:00,148 [thread=http-bio-8443-exec-1]
[id=null, target=COMPLIANCE, type=CREATED, time=Fri Apr 22 09:37:00 CEST
2016-04-22 09:37:00,156 [thread=http-bio-8443-exec-1]
content-type="application/json", time=1903
LOG: duration: 307950.035 ms execute <unnamed>: UPDATE "architectures"
SET "hosts_count" = COALESCE("hosts_count", 0) + 1 WHERE
"architectures"."id" = 1
2016-04-22 09:37:00,629 [thread=http-bio-8443-exec-4]
[req=6627eb58-c365-448c-add1-18e964f9a39d, org=] INFO
uri=/candlepin/consumers/a3569c27-09e8-45a4-9285-aefe7029c9a5
2016-04-22 09:37:00,689 [thread=http-bio-8443-exec-4]
[req=6627eb58-c365-448c-add1-18e964f9a39d, org=Default_Organization] INFO
content-type="application/json", time=61
2016-04-22 09:37:00,887 [thread=http-bio-8443-exec-9]
[req=afe64765-f0ac-498c-b729-6b2feaa33a4d, org=] INFO
2016-04-22 09:37:00,930 [thread=http-bio-8443-exec-9]
[req=afe64765-f0ac-498c-b729-6b2feaa33a4d, org=Default_Organization] INFO
content-type="application/json", time=43
2016-04-22 09:37:00 [app] [I] Completed 200 OK in 386068ms (Views: 1.3ms |
ActiveRecord: 307207.3ms)
2016-04-21 18:32 GMT+02:00 Chris Duryee :
On 04/21/2016 12:20 PM, Chris Duryee wrote:
On 04/21/2016 12:09 PM, Romain P wrote:
I am currently trying to add hosts on my Katello3.0 RC3 instance.
Each host takes several minutes to be added and the Katello web UI is
not
responding during this time.
Is there any parameter I can tune to not block the web UI or make the
registration faster ?
2016-04-21 18:01:02 [app] [I] Started POST
172.17.0.110 at 2016-04-21 18:01:02 +0200
2016-04-21 18:01:02 [app] [I] Processing by
2016-04-21 18:01:02 [app] [I] Parameters: {“facts”=>"[FILTERED]",
“contentTags”=>nil, “type”=>“system”, “name”=>“30404e7d296c”,
“owner”=>“Default_Organization”, “activation_keys”=>“my-key”}
2016-04-21 18:01:03 [app] [I] Import facts for ‘30404e7d296c’ completed.
2016-04-21 18:02:20 [app] [I] Completed 200 OK in 244429ms (Views:
1.7ms |
ActiveRecord: 157689.1ms)
Kind regards
Romain
Whoops sorry, I misread the API call originally. The below instructions
may not catch the issue:)
Can you post back with the output of /var/log/candlepin/candlepin.log
from around the time you added the host?
You can increase the number of Passenger workers, but it would quickly
be exhausted if registrations are taking that long.
Can you try the following?
- edit /var/lib/pgsql/data/postgresql.conf and edit:
#log_min_duration_statement = -1
to say:
log_min_duration_statement = 500
This will log every SQL query that is taking longer than 1/2 second.
reload postgresql (no need to restart, just “service postgresql
reload”)
perform a host registration
check /var/lib/pgsql/data/pg_log/postgresql-.log
I am guessing there will be at least one slow query in there. If you can
post back with the log from when that ran, we can look into this issue
further.
Thanks!
"Foreman users" group.
