Hello all,
my name is Alex.
I’m using Foreman from some years on VMware environment and provision by vmware template and cloud-init.
Now in my company I need to manage also bare metal servers, then I want to create a common standard and use kickstart for provisioning.
I configure everything and it’s works but I can’t find how i can create something without human task.
I want to create a kickstart menu where the first try is on local disk and if not find anything go to the second option that is install the OS by kickstart.
Now I need to select my self the menu and this take me some minutes more. My intention is to have possibility to launch the installation of different deployment without going and select myself the entry.
Some can help me?
All the best
Alex
