"Linux host_init_config default" script not running after provisioning
When creating, building, and provisioning a new RHEL 8.10 host, the Linux host_init_config default Provisioning Template is not applied. RHEL registration does not occur, Puppet installation/initial run does not occur, and Clevis/Tang enrollment does not occur. There don’t appear to be any logs related to this, e.g. 'Content-Type: text/plain' --data 'Host initial configuration failed, please see the registration log for more details.' from the curl command in the script (or if there are, I can’t find them). The host OS installs as expected.
After OS provisioning, the script runs and registers the system with RHEL, installs and runs Puppet, and enrolls the system with Tang.
Foreman: 3.15.0
Foreman Proxy: 3.15.0
N/A
Ubuntu 22.04 LTS
We are using the default Linux host_init_config default Provisioning Template. I’ve set the following Global Parameters:
  • activation_key: string
  • disk_enc_tang_servers: array
  • enable-official-puppet8-repo: boolean (true)
  • puppet_server: string
  • subscription_manager: boolean (true)
  • subscription_manager_org: string
Also probably relevant - we have an internal CA that signed the cert for Foreman’s HTTPS traffic, but Puppet clients are using the self-signed certs.
The message you’re seeing “Host initial configuration failed, please see the registration log for more detail” comes from the host_init_config_default provisioning template. That means the template is being executed, but something inside it is failing.
Could you please share:
  • The full output of the registration command
  • The relevant Foreman logs for the registration request from /var/log/foreman/production.log
  • The contents of /root/registration_host_init.sh and its log output on the host (since the error usually points there)
This will help us pinpoint what part of the template is failing.
