luna-nightly-rpm-pipeline 101 failed
Luna nightly pipeline failed:
https://ci.theforeman.org/job/luna-nightly-rpm-pipeline/101/
This doesnt seem to be getting very far at all with this error:
ERROR: Attempted to execute a step that requires a node context while ‘agent none’ was specified. Be sure to specify your own ‘node { … }’ blocks when using ‘agent none’.
@evgeni could this be related to
Looks like, yeah
Can you or @ekohl try to fix that? I’m out till Friday.
Thanks!
Needs an agent statement in https://github.com/theforeman/foreman-infra/blob/master/puppet/modules/jenkins_job_builder/files/theforeman.org/pipelines/release/luna/nightly.groovy like in my PR. Sorry for overlooking that.
No worries! Thanks for the pointer, i opened
It looks like it was failing before this breakage anyways, so nothing
was lost :wink: But those runs don’t have any output whatsoever on the
upgrade test, so i’m curious if a fresh run will.
https://ci.centos.org/job/foreman-luna-upgrade-nightly-test/100/console
Justin
