luna-nightly-rpm-pipeline 297 failed
Luna nightly pipeline failed:
https://ci.theforeman.org/job/luna-nightly-rpm-pipeline/297/
foreman-pipeline-luna-nightly-centos7-install (failed) (remote job)
foreman-pipeline-luna-nightly-centos8-install (failed) (remote job)
foreman-pipeline-luna-nightly-centos8-stream-install (failed) (remote job)
foreman-pipeline-luna-nightly-centos7-upgrade (passed) (remote job)
foreman-pipeline-luna-nightly-centos8-upgrade (passed) (remote job)
tl;dr: db:seed fails with:
ActiveRecord::NotNullViolation: PG::NotNullViolation: ERROR:  null value in column "host_action_button" violates not-null constraint
DETAIL:  Failing row contains (22, foreman_openscap_run_oval_scans, Run OVAL scan, Run OVAL scan, , null, null, null, null).
Full error:
2021-10-21 04:34:21 [DEBUG ] [configure] /Stage[main]/Foreman::Database/Foreman::Rake[db:seed]/Exec[foreman-rake-db:seed]: Starting to evaluate the resource (1396 of 2082)
2021-10-21 04:34:21 [DEBUG ] [configure] /Stage[main]/Foreman::Database/Foreman::Rake[db:seed]/Exec[foreman-rake-db:seed]: '/usr/sbin/foreman-rake db:seed' won't be executed because of failed check 'refreshonly'
2021-10-21 04:34:21 [DEBUG ] [configure] Exec[foreman-rake-db:seed](provider=posix): Executing '/usr/sbin/foreman-rake db:seed'
2021-10-21 04:34:21 [DEBUG ] [configure] Executing with uid=foreman: '/usr/sbin/foreman-rake db:seed'
2021-10-21 04:34:43 [INFO  ] [configure] /Stage[main]/Foreman::Database/Foreman::Rake[db:seed]/Exec[foreman-rake-db:seed]/returns: Apipie cache enabled but not present yet. Run apipie:cache rake task to speed up API calls.
2021-10-21 04:34:43 [INFO  ] [configure] /Stage[main]/Foreman::Database/Foreman::Rake[db:seed]/Exec[foreman-rake-db:seed]/returns: rake aborted!
2021-10-21 04:34:43 [INFO  ] [configure] /Stage[main]/Foreman::Database/Foreman::Rake[db:seed]/Exec[foreman-rake-db:seed]/returns: ActiveRecord::NotNullViolation: PG::NotNullViolation: ERROR:  null value in column "host_action_button" violates not-null constraint
2021-10-21 04:34:43 [INFO  ] [configure] /Stage[main]/Foreman::Database/Foreman::Rake[db:seed]/Exec[foreman-rake-db:seed]/returns: DETAIL:  Failing row contains (22, foreman_openscap_run_oval_scans, Run OVAL scan, Run OVAL scan, , null, null, null, null).
2021-10-21 04:34:43 [INFO  ] [configure] /Stage[main]/Foreman::Database/Foreman::Rake[db:seed]/Exec[foreman-rake-db:seed]/returns: /opt/theforeman/tfm/root/usr/share/gems/gems/activerecord-6.0.3.7/lib/active_record/connection_adapters/postgresql_adapter.rb:675:in `async_exec_params'
2021-10-21 04:34:43 [INFO  ] [configure] /Stage[main]/Foreman::Database/Foreman::Rake[db:seed]/Exec[foreman-rake-db:seed]/returns: /opt/theforeman/tfm/root/usr/share/gems/gems/activerecord-6.0.3.7/lib/active_record/connection_adapters/postgresql_adapter.rb:675:in `block (2 levels) in exec_no_cache'
2021-10-21 04:34:43 [INFO  ] [configure] /Stage[main]/Foreman::Database/Foreman::Rake[db:seed]/Exec[foreman-rake-db:seed]/returns: /opt/theforeman/tfm/root/usr/share/gems/gems/activesupport-6.0.3.7/lib/active_support/dependencies/interlock.rb:48:in `block in permit_concurrent_loads'
2021-10-21 04:34:43 [INFO  ] [configure] /Stage[main]/Foreman::Database/Foreman::Rake[db:seed]/Exec[foreman-rake-db:seed]/returns: /opt/theforeman/tfm/root/usr/share/gems/gems/activesupport-6.0.3.7/lib/active_support/concurrency/share_lock.rb:187:in `yield_shares'
2021-10-21 04:34:43 [INFO  ] [configure] /Stage[main]/Foreman::Database/Foreman::Rake[db:seed]/Exec[foreman-rake-db:seed]/returns: /opt/theforeman/tfm/root/usr/share/gems/gems/activesupport-6.0.3.7/lib/active_support/dependencies/interlock.rb:47:in `permit_concurrent_loads'
2021-10-21 04:34:43 [INFO  ] [configure] /Stage[main]/Foreman::Database/Foreman::Rake[db:seed]/Exec[foreman-rake-db:seed]/returns: /opt/theforeman/tfm/root/usr/share/gems/gems/activerecord-6.0.3.7/lib/active_record/connection_adapters/postgresql_adapter.rb:674:in `block in exec_no_cache'
2021-10-21 04:34:43 [INFO  ] [configure] /Stage[main]/Foreman::Database/Foreman::Rake[db:seed]/Exec[foreman-rake-db:seed]/returns: /opt/theforeman/tfm/root/usr/share/gems/gems/activerecord-6.0.3.7/lib/active_record/connection_adapters/abstract_adapter.rb:722:in `block (2 levels) in log'
2021-10-21 04:34:43 [INFO  ] [configure] /Stage[main]/Foreman::Database/Foreman::Rake[db:seed]/Exec[foreman-rake-db:seed]/returns: /opt/theforeman/tfm/root/usr/share/gems/gems/activesupport-6.0.3.7/lib/active_support/concurrency/load_interlock_aware_monitor.rb:26:in `block (2 levels) in synchronize'
2021-10-21 04:34:43 [INFO  ] [configure] /Stage[main]/Foreman::Database/Foreman::Rake[db:seed]/Exec[foreman-rake-db:seed]/returns: /opt/theforeman/tfm/root/usr/share/gems/gems/activesupport-6.0.3.7/lib/active_support/concurrency/load_interlock_aware_monitor.rb:25:in `handle_interrupt'
2021-10-21 04:34:43 [INFO  ] [configure] /Stage[main]/Foreman::Database/Foreman::Rake[db:seed]/Exec[foreman-rake-db:seed]/returns: /opt/theforeman/tfm/root/usr/share/gems/gems/activesupport-6.0.3.7/lib/active_support/concurrency/load_interlock_aware_monitor.rb:25:in `block in synchronize'
2021-10-21 04:34:43 [INFO  ] [configure] /Stage[main]/Foreman::Database/Foreman::Rake[db:seed]/Exec[foreman-rake-db:seed]/returns: /opt/theforeman/tfm/root/usr/share/gems/gems/activesupport-6.0.3.7/lib/active_support/concurrency/load_interlock_aware_monitor.rb:21:in `handle_interrupt'
2021-10-21 04:34:43 [INFO  ] [configure] /Stage[main]/Foreman::Database/Foreman::Rake[db:seed]/Exec[foreman-rake-db:seed]/returns: /opt/theforeman/tfm/root/usr/share/gems/gems/activesupport-6.0.3.7/lib/active_support/concurrency/load_interlock_aware_monitor.rb:21:in `synchronize'
2021-10-21 04:34:43 [INFO  ] [configure] /Stage[main]/Foreman::Database/Foreman::Rake[db:seed]/Exec[foreman-rake-db:seed]/returns: /opt/theforeman/tfm/root/usr/share/gems/gems/activerecord-6.0.3.7/lib/active_record/connection_adapters/abstract_adapter.rb:721:in `block in log'
2021-10-21 04:34:43 [INFO  ] [configure] /Stage[main]/Foreman::Database/Foreman::Rake[db:seed]/Exec[foreman-rake-db:seed]/returns: /opt/theforeman/tfm/root/usr/share/gems/gems/activesupport-6.0.3.7/lib/active_support/notifications/instrumenter.rb:24:in `instrument'
2021-10-21 04:34:43 [INFO  ] [configure] /Stage[main]/Foreman::Database/Foreman::Rake[db:seed]/Exec[foreman-rake-db:seed]/returns: /opt/theforeman/tfm/root/usr/share/gems/gems/activerecord-6.0.3.7/lib/active_record/connection_adapters/abstract_adapter.rb:712:in `log'
2021-10-21 04:34:43 [INFO  ] [configure] /Stage[main]/Foreman::Database/Foreman::Rake[db:seed]/Exec[foreman-rake-db:seed]/returns: /opt/theforeman/tfm/root/usr/share/gems/gems/activerecord-6.0.3.7/lib/active_record/connection_adapters/postgresql_adapter.rb:673:in `exec_no_cache'
2021-10-21 04:34:43 [INFO  ] [configure] /Stage[main]/Foreman::Database/Foreman::Rake[db:seed]/Exec[foreman-rake-db:seed]/returns: /opt/theforeman/tfm/root/usr/share/gems/gems/activerecord-6.0.3.7/lib/active_record/connection_adapters/postgresql_adapter.rb:656:in `execute_and_clear'
2021-10-21 04:34:43 [INFO  ] [configure] /Stage[main]/Foreman::Database/Foreman::Rake[db:seed]/Exec[foreman-rake-db:seed]/returns: /opt/theforeman/tfm/root/usr/share/gems/gems/activerecord-6.0.3.7/lib/active_record/connection_adapters/postgresql/database_statements.rb:98:in `exec_query'
2021-10-21 04:34:43 [INFO  ] [configure] /Stage[main]/Foreman::Database/Foreman::Rake[db:seed]/Exec[foreman-rake-db:seed]/returns: /opt/theforeman/tfm/root/usr/share/gems/gems/activerecord-6.0.3.7/lib/active_record/connection_adapters/abstract/database_statements.rb:135:in `exec_insert'
2021-10-21 04:34:43 [INFO  ] [configure] /Stage[main]/Foreman::Database/Foreman::Rake[db:seed]/Exec[foreman-rake-db:seed]/returns: /opt/theforeman/tfm/root/usr/share/gems/gems/activerecord-6.0.3.7/lib/active_record/connection_adapters/postgresql/database_statements.rb:132:in `exec_insert'
2021-10-21 04:34:43 [INFO  ] [configure] /Stage[main]/Foreman::Database/Foreman::Rake[db:seed]/Exec[foreman-rake-db:seed]/returns: /opt/theforeman/tfm/root/usr/share/gems/gems/activerecord-6.0.3.7/lib/active_record/connection_adapters/abstract/database_statements.rb:166:in `insert'
2021-10-21 04:34:43 [INFO  ] [configure] /Stage[main]/Foreman::Database/Foreman::Rake[db:seed]/Exec[foreman-rake-db:seed]/returns: /opt/theforeman/tfm/root/usr/share/gems/gems/activerecord-6.0.3.7/lib/active_record/connection_adapters/abstract/query_cache.rb:22:in `insert'
2021-10-21 04:34:43 [INFO  ] [configure] /Stage[main]/Foreman::Database/Foreman::Rake[db:seed]/Exec[foreman-rake-db:seed]/returns: /opt/theforeman/tfm/root/usr/share/gems/gems/activerecord-6.0.3.7/lib/active_record/persistence.rb:375:in `_insert_record'
2021-10-21 04:34:43 [INFO  ] [configure] /Stage[main]/Foreman::Database/Foreman::Rake[db:seed]/Exec[foreman-rake-db:seed]/returns: /opt/theforeman/tfm/root/usr/share/gems/gems/activerecord-6.0.3.7/lib/active_record/persistence.rb:932:in `_create_record'
2021-10-21 04:34:43 [INFO  ] [configure] /Stage[main]/Foreman::Database/Foreman::Rake[db:seed]/Exec[foreman-rake-db:seed]/returns: /opt/theforeman/tfm/root/usr/share/gems/gems/activerecord-6.0.3.7/lib/active_record/counter_cache.rb:166:in `_create_record'
2021-10-21 04:34:43 [INFO  ] [configure] /Stage[main]/Foreman::Database/Foreman::Rake[db:seed]/Exec[foreman-rake-db:seed]/returns: /opt/theforeman/tfm/root/usr/share/gems/gems/activerecord-6.0.3.7/lib/active_record/locking/optimistic.rb:70:in `_create_record'
2021-10-21 04:34:43 [INFO  ] [configure] /Stage[main]/Foreman::Database/Foreman::Rake[db:seed]/Exec[foreman-rake-db:seed]/returns: /opt/theforeman/tfm/root/usr/share/gems/gems/activerecord-6.0.3.7/lib/active_record/attribute_methods/dirty.rb:211:in `_create_record'
2021-10-21 04:34:43 [INFO  ] [configure] /Stage[main]/Foreman::Database/Foreman::Rake[db:seed]/Exec[foreman-rake-db:seed]/returns: /opt/theforeman/tfm/root/usr/share/gems/gems/activerecord-6.0.3.7/lib/active_record/callbacks.rb:331:in `block in _create_record'
2021-10-21 04:34:43 [INFO  ] [configure] /Stage[main]/Foreman::Database/Foreman::Rake[db:seed]/Exec[foreman-rake-db:seed]/returns: /opt/theforeman/tfm/root/usr/share/gems/gems/activesupport-6.0.3.7/lib/active_support/callbacks.rb:135:in `run_callbacks'
2021-10-21 04:34:43 [INFO  ] [configure] /Stage[main]/Foreman::Database/Foreman::Rake[db:seed]/Exec[foreman-rake-db:seed]/returns: /opt/theforeman/tfm/root/usr/share/gems/gems/activesupport-6.0.3.7/lib/active_support/callbacks.rb:825:in `_run_create_callbacks'
2021-10-21 04:34:43 [INFO  ] [configure] /Stage[main]/Foreman::Database/Foreman::Rake[db:seed]/Exec[foreman-rake-db:seed]/returns: /opt/theforeman/tfm/root/usr/share/gems/gems/activerecord-6.0.3.7/lib/active_record/callbacks.rb:331:in `_create_record'
2021-10-21 04:34:43 [INFO  ] [configure] /Stage[main]/Foreman::Database/Foreman::Rake[db:seed]/Exec[foreman-rake-db:seed]/returns: /opt/theforeman/tfm/root/usr/share/gems/gems/activerecord-6.0.3.7/lib/active_record/timestamp.rb:110:in `_create_record'
2021-10-21 04:34:43 [INFO  ] [configure] /Stage[main]/Foreman::Database/Foreman::Rake[db:seed]/Exec[foreman-rake-db:seed]/returns: /opt/theforeman/tfm/root/usr/share/gems/gems/activerecord-6.0.3.7/lib/active_record/persistence.rb:905:in `create_or_update'
2021-10-21 04:34:43 [INFO  ] [configure] /Stage[main]/Foreman::Database/Foreman::Rake[db:seed]/Exec[foreman-rake-db:seed]/returns: /opt/theforeman/tfm/root/usr/share/gems/gems/activerecord-6.0.3.7/lib/active_record/callbacks.rb:327:in `block in create_or_update'
2021-10-21 04:34:43 [INFO  ] [configure] /Stage[main]/Foreman::Database/Foreman::Rake[db:seed]/Exec[foreman-rake-db:seed]/returns: /opt/theforeman/tfm/root/usr/share/gems/gems/activesupport-6.0.3.7/lib/active_support/callbacks.rb:825:in `_run_save_callbacks'
2021-10-21 04:34:43 [INFO  ] [configure] /Stage[main]/Foreman::Database/Foreman::Rake[db:seed]/Exec[foreman-rake-db:seed]/returns: /opt/theforeman/tfm/root/usr/share/gems/gems/activerecord-6.0.3.7/lib/active_record/callbacks.rb:327:in `create_or_update'
2021-10-21 04:34:43 [INFO  ] [configure] /Stage[main]/Foreman::Database/Foreman::Rake[db:seed]/Exec[foreman-rake-db:seed]/returns: /opt/theforeman/tfm/root/usr/share/gems/gems/activerecord-6.0.3.7/lib/active_record/timestamp.rb:128:in `create_or_update'
2021-10-21 04:34:43 [INFO  ] [configure] /Stage[main]/Foreman::Database/Foreman::Rake[db:seed]/Exec[foreman-rake-db:seed]/returns: /opt/theforeman/tfm/root/usr/share/gems/gems/activerecord-6.0.3.7/lib/active_record/persistence.rb:503:in `save!'
2021-10-21 04:34:43 [INFO  ] [configure] /Stage[main]/Foreman::Database/Foreman::Rake[db:seed]/Exec[foreman-rake-db:seed]/returns: /opt/theforeman/tfm/root/usr/share/gems/gems/activerecord-6.0.3.7/lib/active_record/validations.rb:53:in `save!'
2021-10-21 04:34:43 [INFO  ] [configure] /Stage[main]/Foreman::Database/Foreman::Rake[db:seed]/Exec[foreman-rake-db:seed]/returns: /opt/theforeman/tfm/root/usr/share/gems/gems/activerecord-6.0.3.7/lib/active_record/transactions.rb:318:in `block in save!'
2021-10-21 04:34:43 [INFO  ] [configure] /Stage[main]/Foreman::Database/Foreman::Rake[db:seed]/Exec[foreman-rake-db:seed]/returns: /opt/theforeman/tfm/root/usr/share/gems/gems/activerecord-6.0.3.7/lib/active_record/transactions.rb:375:in `block in with_transaction_returning_status'
2021-10-21 04:34:43 [INFO  ] [configure] /Stage[main]/Foreman::Database/Foreman::Rake[db:seed]/Exec[foreman-rake-db:seed]/returns: /opt/theforeman/tfm/root/usr/share/gems/gems/activerecord-6.0.3.7/lib/active_record/connection_adapters/abstract/database_statements.rb:280:in `block in transaction'
2021-10-21 04:34:43 [INFO  ] [configure] /Stage[main]/Foreman::Database/Foreman::Rake[db:seed]/Exec[foreman-rake-db:seed]/returns: /opt/theforeman/tfm/root/usr/share/gems/gems/activerecord-6.0.3.7/lib/active_record/connection_adapters/abstract/transaction.rb:280:in `block in within_new_transaction'
2021-10-21 04:34:43 [INFO  ] [configure] /Stage[main]/Foreman::Database/Foreman::Rake[db:seed]/Exec[foreman-rake-db:seed]/returns: /opt/theforeman/tfm/root/usr/share/gems/gems/activerecord-6.0.3.7/lib/active_record/connection_adapters/abstract/transaction.rb:278:in `within_new_transaction'
2021-10-21 04:34:43 [INFO  ] [configure] /Stage[main]/Foreman::Database/Foreman::Rake[db:seed]/Exec[foreman-rake-db:seed]/returns: /opt/theforeman/tfm/root/usr/share/gems/gems/activerecord-6.0.3.7/lib/active_record/connection_adapters/abstract/database_statements.rb:280:in `transaction'
2021-10-21 04:34:43 [INFO  ] [configure] /Stage[main]/Foreman::Database/Foreman::Rake[db:seed]/Exec[foreman-rake-db:seed]/returns: /opt/theforeman/tfm/root/usr/share/gems/gems/activerecord-6.0.3.7/lib/active_record/transactions.rb:212:in `transaction'
2021-10-21 04:34:43 [INFO  ] [configure] /Stage[main]/Foreman::Database/Foreman::Rake[db:seed]/Exec[foreman-rake-db:seed]/returns: /opt/theforeman/tfm/root/usr/share/gems/gems/activerecord-6.0.3.7/lib/active_record/transactions.rb:366:in `with_transaction_returning_status'
2021-10-21 04:34:43 [INFO  ] [configure] /Stage[main]/Foreman::Database/Foreman::Rake[db:seed]/Exec[foreman-rake-db:seed]/returns: /opt/theforeman/tfm/root/usr/share/gems/gems/activerecord-6.0.3.7/lib/active_record/transactions.rb:318:in `save!'
2021-10-21 04:34:43 [INFO  ] [configure] /Stage[main]/Foreman::Database/Foreman::Rake[db:seed]/Exec[foreman-rake-db:seed]/returns: /opt/theforeman/tfm/root/usr/share/gems/gems/activerecord-6.0.3.7/lib/active_record/suppressor.rb:48:in `save!'
2021-10-21 04:34:43 [INFO  ] [configure] /Stage[main]/Foreman::Database/Foreman::Rake[db:seed]/Exec[foreman-rake-db:seed]/returns: /opt/theforeman/tfm/root/usr/share/gems/gems/activerecord-6.0.3.7/lib/active_record/persistence.rb:55:in `create!'
2021-10-21 04:34:43 [INFO  ] [configure] /Stage[main]/Foreman::Database/Foreman::Rake[db:seed]/Exec[foreman-rake-db:seed]/returns: /opt/theforeman/tfm/root/usr/share/gems/gems/foreman_remote_execution-4.8.0/app/models/remote_execution_feature.rb:62:in `block in register'
2021-10-21 04:34:43 [INFO  ] [configure] /Stage[main]/Foreman::Database/Foreman::Rake[db:seed]/Exec[foreman-rake-db:seed]/returns: /opt/theforeman/tfm/root/usr/share/gems/gems/audited-4.9.0/lib/audited/auditor.rb:376:in `without_auditing'
2021-10-21 04:34:43 [INFO  ] [configure] /Stage[main]/Foreman::Database/Foreman::Rake[db:seed]/Exec[foreman-rake-db:seed]/returns: /opt/theforeman/tfm/root/usr/share/gems/gems/foreman_remote_execution-4.8.0/app/models/remote_execution_feature.rb:60:in `register'
2021-10-21 04:34:43 [INFO  ] [configure] /Stage[main]/Foreman::Database/Foreman::Rake[db:seed]/Exec[foreman-rake-db:seed]/returns: /opt/theforeman/tfm/root/usr/share/gems/gems/foreman_openscap-5.0.0/lib/foreman_openscap/engine.rb:283:in `block in <class:Engine>'
2021-10-21 04:34:43 [INFO  ] [configure] /Stage[main]/Foreman::Database/Foreman::Rake[db:seed]/Exec[foreman-rake-db:seed]/returns: /opt/theforeman/tfm/root/usr/share/gems/gems/activesupport-6.0.3.7/lib/active_support/callbacks.rb:428:in `instance_exec'
2021-10-21 04:34:43 [INFO  ] [configure] /Stage[main]/Foreman::Database/Foreman::Rake[db:seed]/Exec[foreman-rake-db:seed]/returns: /opt/theforeman/tfm/root/usr/share/gems/gems/activesupport-6.0.3.7/lib/active_support/callbacks.rb:428:in `block in make_lambda'
2021-10-21 04:34:43 [INFO  ] [configure] /Stage[main]/Foreman::Database/Foreman::Rake[db:seed]/Exec[foreman-rake-db:seed]/returns: /opt/theforeman/tfm/root/usr/share/gems/gems/activesupport-6.0.3.7/lib/active_support/callbacks.rb:200:in `block (2 levels) in halting'
2021-10-21 04:34:43 [INFO  ] [configure] /Stage[main]/Foreman::Database/Foreman::Rake[db:seed]/Exec[foreman-rake-db:seed]/returns: /opt/theforeman/tfm/root/usr/share/gems/gems/activesupport-6.0.3.7/lib/active_support/callbacks.rb:605:in `block (2 levels) in default_terminator'
2021-10-21 04:34:43 [INFO  ] [configure] /Stage[main]/Foreman::Database/Foreman::Rake[db:seed]/Exec[foreman-rake-db:seed]/returns: /opt/theforeman/tfm/root/usr/share/gems/gems/activesupport-6.0.3.7/lib/active_support/callbacks.rb:604:in `catch'
2021-10-21 04:34:43 [INFO  ] [configure] /Stage[main]/Foreman::Database/Foreman::Rake[db:seed]/Exec[foreman-rake-db:seed]/returns: /opt/theforeman/tfm/root/usr/share/gems/gems/activesupport-6.0.3.7/lib/active_support/callbacks.rb:604:in `block in default_terminator'
2021-10-21 04:34:43 [INFO  ] [configure] /Stage[main]/Foreman::Database/Foreman::Rake[db:seed]/Exec[foreman-rake-db:seed]/returns: /opt/theforeman/tfm/root/usr/share/gems/gems/activesupport-6.0.3.7/lib/active_support/callbacks.rb:201:in `block in halting'
2021-10-21 04:34:43 [INFO  ] [configure] /Stage[main]/Foreman::Database/Foreman::Rake[db:seed]/Exec[foreman-rake-db:seed]/returns: /opt/theforeman/tfm/root/usr/share/gems/gems/activesupport-6.0.3.7/lib/active_support/callbacks.rb:513:in `block in invoke_before'
2021-10-21 04:34:43 [INFO  ] [configure] /Stage[main]/Foreman::Database/Foreman::Rake[db:seed]/Exec[foreman-rake-db:seed]/returns: /opt/theforeman/tfm/root/usr/share/gems/gems/activesupport-6.0.3.7/lib/active_support/callbacks.rb:513:in `each'
2021-10-21 04:34:43 [INFO  ] [configure] /Stage[main]/Foreman::Database/Foreman::Rake[db:seed]/Exec[foreman-rake-db:seed]/returns: /opt/theforeman/tfm/root/usr/share/gems/gems/activesupport-6.0.3.7/lib/active_support/callbacks.rb:513:in `invoke_before'
2021-10-21 04:34:43 [INFO  ] [configure] /Stage[main]/Foreman::Database/Foreman::Rake[db:seed]/Exec[foreman-rake-db:seed]/returns: /opt/theforeman/tfm/root/usr/share/gems/gems/activesupport-6.0.3.7/lib/active_support/callbacks.rb:134:in `run_callbacks'
2021-10-21 04:34:43 [INFO  ] [configure] /Stage[main]/Foreman::Database/Foreman::Rake[db:seed]/Exec[foreman-rake-db:seed]/returns: /opt/theforeman/tfm/root/usr/share/gems/gems/activesupport-6.0.3.7/lib/active_support/reloader.rb:88:in `prepare!'
2021-10-21 04:34:43 [INFO  ] [configure] /Stage[main]/Foreman::Database/Foreman::Rake[db:seed]/Exec[foreman-rake-db:seed]/returns: /opt/theforeman/tfm/root/usr/share/gems/gems/railties-6.0.3.7/lib/rails/application/finisher.rb:113:in `block in <module:Finisher>'
2021-10-21 04:34:43 [INFO  ] [configure] /Stage[main]/Foreman::Database/Foreman::Rake[db:seed]/Exec[foreman-rake-db:seed]/returns: /opt/theforeman/tfm/root/usr/share/gems/gems/railties-6.0.3.7/lib/rails/initializable.rb:32:in `instance_exec'
2021-10-21 04:34:43 [INFO  ] [configure] /Stage[main]/Foreman::Database/Foreman::Rake[db:seed]/Exec[foreman-rake-db:seed]/returns: /opt/theforeman/tfm/root/usr/share/gems/gems/railties-6.0.3.7/lib/rails/initializable.rb:32:in `run'
2021-10-21 04:34:43 [INFO  ] [configure] /Stage[main]/Foreman::Database/Foreman::Rake[db:seed]/Exec[foreman-rake-db:seed]/returns: /usr/share/foreman/config/initializers/0_print_time_spent.rb:45:in `block in run'
2021-10-21 04:34:43 [INFO  ] [configure] /Stage[main]/Foreman::Database/Foreman::Rake[db:seed]/Exec[foreman-rake-db:seed]/returns: /usr/share/foreman/config/initializers/0_print_time_spent.rb:17:in `benchmark'
2021-10-21 04:34:43 [INFO  ] [configure] /Stage[main]/Foreman::Database/Foreman::Rake[db:seed]/Exec[foreman-rake-db:seed]/returns: /usr/share/foreman/config/initializers/0_print_time_spent.rb:45:in `run'
2021-10-21 04:34:43 [INFO  ] [configure] /Stage[main]/Foreman::Database/Foreman::Rake[db:seed]/Exec[foreman-rake-db:seed]/returns: /opt/theforeman/tfm/root/usr/share/gems/gems/railties-6.0.3.7/lib/rails/initializable.rb:61:in `block in run_initializers'
2021-10-21 04:34:43 [INFO  ] [configure] /Stage[main]/Foreman::Database/Foreman::Rake[db:seed]/Exec[foreman-rake-db:seed]/returns: /opt/theforeman/tfm/root/usr/share/gems/gems/railties-6.0.3.7/lib/rails/initializable.rb:60:in `run_initializers'
2021-10-21 04:34:43 [INFO  ] [configure] /Stage[main]/Foreman::Database/Foreman::Rake[db:seed]/Exec[foreman-rake-db:seed]/returns: /opt/theforeman/tfm/root/usr/share/gems/gems/railties-6.0.3.7/lib/rails/application.rb:363:in `initialize!'
2021-10-21 04:34:43 [INFO  ] [configure] /Stage[main]/Foreman::Database/Foreman::Rake[db:seed]/Exec[foreman-rake-db:seed]/returns: /opt/theforeman/tfm/root/usr/share/gems/gems/railties-6.0.3.7/lib/rails/railtie.rb:190:in `public_send'
2021-10-21 04:34:43 [INFO  ] [configure] /Stage[main]/Foreman::Database/Foreman::Rake[db:seed]/Exec[foreman-rake-db:seed]/returns: /opt/theforeman/tfm/root/usr/share/gems/gems/railties-6.0.3.7/lib/rails/railtie.rb:190:in `method_missing'
2021-10-21 04:34:43 [INFO  ] [configure] /Stage[main]/Foreman::Database/Foreman::Rake[db:seed]/Exec[foreman-rake-db:seed]/returns: /usr/share/foreman/config/environment.rb:5:in `<top (required)>'
2021-10-21 04:34:43 [INFO  ] [configure] /Stage[main]/Foreman::Database/Foreman::Rake[db:seed]/Exec[foreman-rake-db:seed]/returns: /opt/theforeman/tfm/root/usr/share/gems/gems/polyglot-0.3.5/lib/polyglot.rb:65:in `require'
2021-10-21 04:34:43 [INFO  ] [configure] /Stage[main]/Foreman::Database/Foreman::Rake[db:seed]/Exec[foreman-rake-db:seed]/returns: /opt/theforeman/tfm/root/usr/share/gems/gems/activesupport-6.0.3.7/lib/active_support/dependencies.rb:324:in `block in require'
2021-10-21 04:34:43 [INFO  ] [configure] /Stage[main]/Foreman::Database/Foreman::Rake[db:seed]/Exec[foreman-rake-db:seed]/returns: /opt/theforeman/tfm/root/usr/share/gems/gems/activesupport-6.0.3.7/lib/active_support/dependencies.rb:291:in `load_dependency'
2021-10-21 04:34:43 [INFO  ] [configure] /Stage[main]/Foreman::Database/Foreman::Rake[db:seed]/Exec[foreman-rake-db:seed]/returns: /opt/theforeman/tfm/root/usr/share/gems/gems/activesupport-6.0.3.7/lib/active_support/dependencies.rb:324:in `require'
2021-10-21 04:34:43 [INFO  ] [configure] /Stage[main]/Foreman::Database/Foreman::Rake[db:seed]/Exec[foreman-rake-db:seed]/returns: /opt/theforeman/tfm/root/usr/share/gems/gems/railties-6.0.3.7/lib/rails/application.rb:339:in `require_environment!'
2021-10-21 04:34:43 [INFO  ] [configure] /Stage[main]/Foreman::Database/Foreman::Rake[db:seed]/Exec[foreman-rake-db:seed]/returns: /opt/theforeman/tfm/root/usr/share/gems/gems/railties-6.0.3.7/lib/rails/application.rb:523:in `block in run_tasks_blocks'
2021-10-21 04:34:43 [INFO  ] [configure] /Stage[main]/Foreman::Database/Foreman::Rake[db:seed]/Exec[foreman-rake-db:seed]/returns: /opt/rh/rh-ruby27/root/usr/share/gems/gems/rake-13.0.1/exe/rake:27:in `<top (required)>'
2021-10-21 04:34:43 [INFO  ] [configure] /Stage[main]/Foreman::Database/Foreman::Rake[db:seed]/Exec[foreman-rake-db:seed]/returns: Caused by:
2021-10-21 04:34:43 [INFO  ] [configure] /Stage[main]/Foreman::Database/Foreman::Rake[db:seed]/Exec[foreman-rake-db:seed]/returns: PG::NotNullViolation: ERROR:  null value in column "host_action_button" violates not-null constraint
2021-10-21 04:34:43 [INFO  ] [configure] /Stage[main]/Foreman::Database/Foreman::Rake[db:seed]/Exec[foreman-rake-db:seed]/returns: Tasks: TOP => db:seed => db:load_config => environment
2021-10-21 04:34:43 [INFO  ] [configure] /Stage[main]/Foreman::Database/Foreman::Rake[db:seed]/Exec[foreman-rake-db:seed]/returns: (See full trace by running task with --trace)
2021-10-21 04:34:43 [ERROR ] [configure] /Stage[main]/Foreman::Database/Foreman::Rake[db:seed]/Exec[foreman-rake-db:seed]: Failed to call refresh: '/usr/sbin/foreman-rake db:seed' returned 1 instead of one of [0]
2021-10-21 04:34:43 [ERROR ] [configure] /Stage[main]/Foreman::Database/Foreman::Rake[db:seed]/Exec[foreman-rake-db:seed]: '/usr/sbin/foreman-rake db:seed' returned 1 instead of one of [0]
2021-10-21 04:34:43 [DEBUG ] [configure] /Stage[main]/Foreman::Database/Foreman::Rake[db:seed]/Exec[foreman-rake-db:seed]: Evaluated in 21.96 seconds
Is this a REX failure or does it come from OpenSCAP? @aruzicka or @Ondrej_Prazak?
Interestingly, I’ve been running into this issue a lot when rails has been reloading in development.
Looks like this should fix it:
Probably needs a new openscap release with it to fix the pipeline, @Ondrej_Prazak can you cut one please?
