jenkins
January 7, 2022, 10:54am
#1
ekohl
January 7, 2022, 11:40am
#2
Looks like db:migrate fails with a migration in bootdisk. @lzap any idea?
Apipie cache enabled but not present yet. Run apipie:cache rake task to speed up API calls.
rake aborted!
StandardError: An error has occurred, this and all later migrations canceled:
PG::UndefinedTable: ERROR: relation "templates" does not exist
LINE 8: WHERE a.attrelid = '"templates"'::regclass
/opt/theforeman/tfm/root/usr/share/gems/gems/activerecord-6.0.3.7/lib/active_record/connection_adapters/postgresql/database_statements.rb:65:in `async_exec'
/opt/theforeman/tfm/root/usr/share/gems/gems/activerecord-6.0.3.7/lib/active_record/connection_adapters/postgresql/database_statements.rb:65:in `block (2 levels) in query'
/opt/theforeman/tfm/root/usr/share/gems/gems/activesupport-6.0.3.7/lib/active_support/dependencies/interlock.rb:48:in `block in permit_concurrent_loads'
/opt/theforeman/tfm/root/usr/share/gems/gems/activesupport-6.0.3.7/lib/active_support/concurrency/share_lock.rb:187:in `yield_shares'
/opt/theforeman/tfm/root/usr/share/gems/gems/activesupport-6.0.3.7/lib/active_support/dependencies/interlock.rb:47:in `permit_concurrent_loads'
/opt/theforeman/tfm/root/usr/share/gems/gems/activerecord-6.0.3.7/lib/active_record/connection_adapters/postgresql/database_statements.rb:64:in `block in query'
/opt/theforeman/tfm/root/usr/share/gems/gems/activerecord-6.0.3.7/lib/active_record/connection_adapters/abstract_adapter.rb:722:in `block (2 levels) in log'
/opt/theforeman/tfm/root/usr/share/gems/gems/activesupport-6.0.3.7/lib/active_support/concurrency/load_interlock_aware_monitor.rb:26:in `block (2 levels) in synchronize'
/opt/theforeman/tfm/root/usr/share/gems/gems/activesupport-6.0.3.7/lib/active_support/concurrency/load_interlock_aware_monitor.rb:25:in `handle_interrupt'
/opt/theforeman/tfm/root/usr/share/gems/gems/activesupport-6.0.3.7/lib/active_support/concurrency/load_interlock_aware_monitor.rb:25:in `block in synchronize'
/opt/theforeman/tfm/root/usr/share/gems/gems/activesupport-6.0.3.7/lib/active_support/concurrency/load_interlock_aware_monitor.rb:21:in `handle_interrupt'
/opt/theforeman/tfm/root/usr/share/gems/gems/activesupport-6.0.3.7/lib/active_support/concurrency/load_interlock_aware_monitor.rb:21:in `synchronize'
/opt/theforeman/tfm/root/usr/share/gems/gems/activerecord-6.0.3.7/lib/active_record/connection_adapters/abstract_adapter.rb:721:in `block in log'
/opt/theforeman/tfm/root/usr/share/gems/gems/activesupport-6.0.3.7/lib/active_support/notifications/instrumenter.rb:24:in `instrument'
/opt/theforeman/tfm/root/usr/share/gems/gems/activerecord-6.0.3.7/lib/active_record/connection_adapters/abstract_adapter.rb:712:in `log'
/opt/theforeman/tfm/root/usr/share/gems/gems/activerecord-6.0.3.7/lib/active_record/connection_adapters/postgresql/database_statements.rb:63:in `query'
/opt/theforeman/tfm/root/usr/share/gems/gems/activerecord-6.0.3.7/lib/active_record/connection_adapters/postgresql_adapter.rb:820:in `column_definitions'
/opt/theforeman/tfm/root/usr/share/gems/gems/activerecord-6.0.3.7/lib/active_record/connection_adapters/abstract/schema_statements.rb:114:in `columns'
/opt/theforeman/tfm/root/usr/share/gems/gems/activerecord-6.0.3.7/lib/active_record/connection_adapters/schema_cache.rb:76:in `columns'
/opt/theforeman/tfm/root/usr/share/gems/gems/activerecord-6.0.3.7/lib/active_record/connection_adapters/schema_cache.rb:82:in `columns_hash'
/opt/theforeman/tfm/root/usr/share/gems/gems/activerecord-6.0.3.7/lib/active_record/model_schema.rb:488:in `load_schema!'
/opt/theforeman/tfm/root/usr/share/gems/gems/activerecord-6.0.3.7/lib/active_record/attributes.rb:247:in `load_schema!'
/opt/theforeman/tfm/root/usr/share/gems/gems/activerecord-6.0.3.7/lib/active_record/attribute_decorators.rb:50:in `load_schema!'
/opt/theforeman/tfm/root/usr/share/gems/gems/activerecord-6.0.3.7/lib/active_record/model_schema.rb:478:in `block in load_schema'
/opt/theforeman/tfm/root/usr/share/gems/gems/activerecord-6.0.3.7/lib/active_record/model_schema.rb:475:in `synchronize'
/opt/theforeman/tfm/root/usr/share/gems/gems/activerecord-6.0.3.7/lib/active_record/model_schema.rb:475:in `load_schema'
/opt/theforeman/tfm/root/usr/share/gems/gems/activerecord-6.0.3.7/lib/active_record/model_schema.rb:362:in `attribute_types'
/opt/theforeman/tfm/root/usr/share/gems/gems/activerecord-6.0.3.7/lib/active_record/model_schema.rb:386:in `type_for_attribute'
/opt/theforeman/tfm/root/usr/share/gems/gems/activerecord-6.0.3.7/lib/active_record/table_metadata.rb:33:in `type'
/opt/theforeman/tfm/root/usr/share/gems/gems/activerecord-6.0.3.7/lib/active_record/relation/predicate_builder.rb:51:in `build'
/opt/theforeman/tfm/root/usr/share/gems/gems/activerecord-6.0.3.7/lib/active_record/relation/predicate_builder.rb:109:in `block in expand_from_hash'
/opt/theforeman/tfm/root/usr/share/gems/gems/activerecord-6.0.3.7/lib/active_record/relation/predicate_builder.rb:68:in `each'
/opt/theforeman/tfm/root/usr/share/gems/gems/activerecord-6.0.3.7/lib/active_record/relation/predicate_builder.rb:68:in `flat_map'
/opt/theforeman/tfm/root/usr/share/gems/gems/activerecord-6.0.3.7/lib/active_record/relation/predicate_builder.rb:68:in `expand_from_hash'
/opt/theforeman/tfm/root/usr/share/gems/gems/activerecord-6.0.3.7/lib/active_record/relation/predicate_builder.rb:21:in `build_from_hash'
/opt/theforeman/tfm/root/usr/share/gems/gems/activerecord-6.0.3.7/lib/active_record/relation/where_clause_factory.rb:19:in `build'
/opt/theforeman/tfm/root/usr/share/gems/gems/activerecord-6.0.3.7/lib/active_record/relation/query_methods.rb:656:in `where!'
/opt/theforeman/tfm/root/usr/share/gems/gems/activerecord-6.0.3.7/lib/active_record/relation/query_methods.rb:649:in `where'
/opt/theforeman/tfm/root/usr/share/gems/gems/foreman_bootdisk-19.0.0/db/migrate/20140522185700_change_templatekind_to_bootdisk.rb:11:in `up'
/opt/theforeman/tfm/root/usr/share/gems/gems/activerecord-6.0.3.7/lib/active_record/migration.rb:791:in `up'
/opt/theforeman/tfm/root/usr/share/gems/gems/activerecord-6.0.3.7/lib/active_record/migration.rb:831:in `exec_migration'
/opt/theforeman/tfm/root/usr/share/gems/gems/activerecord-6.0.3.7/lib/active_record/migration.rb:812:in `block (2 levels) in migrate'
/opt/theforeman/tfm/root/usr/share/gems/gems/activerecord-6.0.3.7/lib/active_record/migration.rb:811:in `block in migrate'
/opt/theforeman/tfm/root/usr/share/gems/gems/activerecord-6.0.3.7/lib/active_record/connection_adapters/abstract/connection_pool.rb:471:in `with_connection'
/opt/theforeman/tfm/root/usr/share/gems/gems/activerecord-6.0.3.7/lib/active_record/migration.rb:810:in `migrate'
/opt/theforeman/tfm/root/usr/share/gems/gems/activerecord-6.0.3.7/lib/active_record/migration.rb:1002:in `migrate'
/opt/theforeman/tfm/root/usr/share/gems/gems/activerecord-6.0.3.7/lib/active_record/migration.rb:1310:in `block in execute_migration_in_transaction'
/opt/theforeman/tfm/root/usr/share/gems/gems/activerecord-6.0.3.7/lib/active_record/migration.rb:1361:in `block in ddl_transaction'
/opt/theforeman/tfm/root/usr/share/gems/gems/activerecord-6.0.3.7/lib/active_record/connection_adapters/abstract/database_statements.rb:280:in `block in transaction'
/opt/theforeman/tfm/root/usr/share/gems/gems/activerecord-6.0.3.7/lib/active_record/connection_adapters/abstract/transaction.rb:280:in `block in within_new_transaction'
/opt/theforeman/tfm/root/usr/share/gems/gems/activerecord-6.0.3.7/lib/active_record/connection_adapters/abstract/transaction.rb:278:in `within_new_transaction'
/opt/theforeman/tfm/root/usr/share/gems/gems/activerecord-6.0.3.7/lib/active_record/connection_adapters/abstract/database_statements.rb:280:in `transaction'
/opt/theforeman/tfm/root/usr/share/gems/gems/activerecord-6.0.3.7/lib/active_record/transactions.rb:212:in `transaction'
/opt/theforeman/tfm/root/usr/share/gems/gems/activerecord-6.0.3.7/lib/active_record/migration.rb:1361:in `ddl_transaction'
/opt/theforeman/tfm/root/usr/share/gems/gems/activerecord-6.0.3.7/lib/active_record/migration.rb:1309:in `execute_migration_in_transaction'
/opt/theforeman/tfm/root/usr/share/gems/gems/activerecord-6.0.3.7/lib/active_record/migration.rb:1281:in `block in migrate_without_lock'
/opt/theforeman/tfm/root/usr/share/gems/gems/activerecord-6.0.3.7/lib/active_record/migration.rb:1280:in `each'
/opt/theforeman/tfm/root/usr/share/gems/gems/activerecord-6.0.3.7/lib/active_record/migration.rb:1280:in `migrate_without_lock'
/opt/theforeman/tfm/root/usr/share/gems/gems/activerecord-6.0.3.7/lib/active_record/migration.rb:1229:in `block in migrate'
/opt/theforeman/tfm/root/usr/share/gems/gems/activerecord-6.0.3.7/lib/active_record/migration.rb:1382:in `with_advisory_lock'
/opt/theforeman/tfm/root/usr/share/gems/gems/activerecord-6.0.3.7/lib/active_record/migration.rb:1229:in `migrate'
/opt/theforeman/tfm/root/usr/share/gems/gems/activerecord-6.0.3.7/lib/active_record/migration.rb:1061:in `up'
/opt/theforeman/tfm/root/usr/share/gems/gems/activerecord-6.0.3.7/lib/active_record/migration.rb:1036:in `migrate'
/opt/theforeman/tfm/root/usr/share/gems/gems/activerecord-6.0.3.7/lib/active_record/tasks/database_tasks.rb:238:in `migrate'
/opt/theforeman/tfm/root/usr/share/gems/gems/activerecord-6.0.3.7/lib/active_record/railties/databases.rake:86:in `block (3 levels) in <top (required)>'
/opt/theforeman/tfm/root/usr/share/gems/gems/activerecord-6.0.3.7/lib/active_record/railties/databases.rake:84:in `each'
/opt/theforeman/tfm/root/usr/share/gems/gems/activerecord-6.0.3.7/lib/active_record/railties/databases.rake:84:in `block (2 levels) in <top (required)>'
/opt/rh/rh-ruby27/root/usr/share/gems/gems/rake-13.0.1/exe/rake:27:in `<top (required)>'
Caused by:
ActiveRecord::StatementInvalid: PG::UndefinedTable: ERROR: relation "templates" does not exist
Caused by:
Tasks: TOP => db:migrate
== 20140522185700 ChangeTemplatekindToBootdisk: migrating =====================
lzap
January 7, 2022, 2:10pm
#3
I havenāt touched this in a while. There was a problem with JS libraries the other day but @evgeni solved it. This looks different, but isnāt this just a consequence of JS not being able to do something? I vaguely remember seeing the very same error.
ekohl
January 7, 2022, 3:03pm
#4
AFAIK the JS issues were on Debian, not on RPMs. I wonder if itās related to:
committed 02:38PM - 11 Nov 21 UTC
All data migrations only modify data on upgrades. On new installs they
are not r⦠equired. Since we do not generally support upgrading multiple
releases, we can clean up old data migrations. This commit cleans up all
the data migrations that were present before Foreman 2.0.
Note that 20140522185700_change_templatekind_to_bootdisk.rb
is quite old.
evgeni
January 7, 2022, 3:42pm
#5
I bet on Evgeniās link, in 2014 Provisioning Template probably were not yet using STI as Partition tables were a stand alone model. Migrations should never use models directly, simply because they always reflect the current code version, thatās why we had FakeModels in migrations. FakeModels unfortunatelly donāt play nicely with STI and we need to update the type after the migration is done manually.
lzap
January 10, 2022, 12:19pm
#7
So I am reverting the change:
theforeman:master
ā lzap:revert-sti-migration
opened 12:17PM - 10 Jan 22 UTC
This reverts commit 8145219c02a0cad97a15aee727e56f3e8867c76a.
https://community⦠.theforeman.org/t/luna-nightly-rpm-pipeline-322-failed/26760
I wonder why bootdisk tests were green, we do run db migrations on jenkins for each plugin. Why it fails on nightly?
system
Closed
January 17, 2022, 12:19pm
#8
lzap
January 19, 2022, 10:10am
#9
So I backported the change, tested it on my instance and a user reports another error:
If you really uninstall the package, then it is not possible to see this error. The file that causes the issue should be uninstalled by package manager.
You can just upgrade the RPM/DEB package to the newer version and you will be fine. Do this:
dnf update https://yum.theforeman.org/plugins/nightly/el8/x86_64/rubygem-foreman_bootdisk-19.0.2-1.fm3_2.el8.noarch.rpm
Cheers!
Invalid single-table inheritance type: ProvisioningTemplate is not a subclass of ChangeTemplatekindToBootdisk::FakeConfigTemplate
Just for the record, we might need another fix.
