[2022-05-02T12:29:30.197Z] e[0;31m 2022-05-02 12:11:32 [ERROR ] [configure] Could not set 'file' on ensure: No such file or directory - A directory component in /etc/mosquitto/mosquitto.conf20220502-25915-2sgpu9.lock does not exist or is a dangling symbolic link (file: /usr/share/foreman-installer/modules/mosquitto/manifests/config.pp, line: 13)e[0m
[2022-05-02T12:29:30.197Z] e[0;31m 2022-05-02 12:11:32 [ERROR ] [configure] Wrapped exception:e[0m
[2022-05-02T12:29:30.197Z] e[0;31m 2022-05-02 12:11:32 [ERROR ] [configure] No such file or directory - A directory component in /etc/mosquitto/mosquitto.conf20220502-25915-2sgpu9.lock does not exist or is a dangling symbolic linke[0m
[2022-05-02T12:29:30.197Z] e[0;31m 2022-05-02 12:11:32 [ERROR ] [configure] /Stage[main]/Mosquitto::Config/File[/etc/mosquitto/mosquitto.conf]/ensure: change from 'absent' to 'file' failed: Could not set 'file' on ensure: No such file or directory - A directory component in /etc/mosquitto/mosquitto.conf20220502-25915-2sgpu9.lock does not exist or is a dangling symbolic link (file: /usr/share/foreman-installer/modules/mosquitto/manifests/config.pp, line: 13)e[0m
[2022-05-02T12:29:30.197Z] e[0;31m 2022-05-02 12:11:32 [ERROR ] [configure] /Stage[main]/Foreman_proxy::Plugin::Remote_execution::Mosquitto/File[/etc/mosquitto/ssl/ssl_cert.pem]: Could not evaluate: Could not retrieve information from environment production source(s) file:///etc/foreman-proxy/ssl_cert.peme[0m
[2022-05-02T12:29:30.197Z] e[0;31m 2022-05-02 12:11:32 [ERROR ] [configure] /Stage[main]/Foreman_proxy::Plugin::Remote_execution::Mosquitto/File[/etc/mosquitto/ssl/ssl_key.pem]: Could not evaluate: Could not retrieve information from environment production source(s) file:///etc/foreman-proxy/ssl_key.peme[0m
