luna-nightly-rpm-pipeline 66 failed
Luna nightly pipeline failed:
https://ci.theforeman.org/job/luna-nightly-rpm-pipeline/66/
foreman-luna-upgrade-nightly-test (failed)
foreman-luna-nightly-test (passed)
ERROR: Unrecognised option '--enable-foreman-cli-virt-who-configure'
This due to my cleanup which uses installer parameters. These don’t exist in released versions which causes upgrade issues.
We can revert this now, but we’ll need this when we introduce EL8 support. It’s probably best to revert now and add the parameters to the released versions.
Sounds reasonable, but looks like reverting via github isn’t available due to commits added after this one.
As a side note, looks like centosci only shows the logs for the last run and not any previous ones.
So we should revert it for now:
Then we add it to 1.22.1 which should fix the upgrades:
