Has anyone been successful in using the "makara" Rubygem to route DB reads
to a DB read replica? (Or can recommend some other approach?)
I'm running into a problem where when I use the "postgresql_makara"
adapter, the scoped search evaluates a particular search query on the
Foreman dashboard into invalid Postgres SQL, causing the DB to reject the
query with an error.
Specifically, it's this line:
When I run with the plain "postgresql" Rails DB adapter, the SQL translates
to:
SELECT COUNT(*) FROM "hosts" WHERE "hosts"."type" IN ('Host::Managed') AND
(((NOT COALESCE("hosts"."last_report" IS NOT NULL, false)) AND
(("hosts"."enabled" <> 'f'))))
However when I run using "postgresql_makara" I'm getting:
(((NOT COALESCE("hosts"."last_report" IS NOT NULL, 0)) AND
The COALESCE statement should resolve to a boolean value, but the default
is an integer – 0 – instead of a boolean – false, which causes
PostgreSQL to throw a PGError.
I can see in the scoped_search code where the Postgres-specific SQL should
be generated
(https://github.com/wvanbergen/scoped_search/blob/master/lib/scoped_search/query_builder.rb#L529),
but I'm not really understanding how the generation is routed based on the
adapter. It seems like there's something in the chain of execution that
isn't recognizing the Makara adapter as a valid PostgreSQL adapter, but I'm
just not seeing where
…I suppose I will need to either directly patch this to get it working or
monkey patch it somewhere.
> https://github.com/theforeman/foreman/blob/94508562b8c10b8b53dcb0badaa8abe31887d059/app/services/dashboard/data.rb#L50
> translates to:
> AND (((NOT COALESCE("hosts"."last_report" IS NOT NULL, false)) AND
> AND (((NOT COALESCE("hosts"."last_report" IS NOT NULL, 0)) AND
> is an integer -- 0 -- instead of a boolean -- false, which causes
> be generated (
> Appreciate the help!
loads a DB-specific class if it exists, which is the PostgreSQL you
found at the bottom:
You could probably define a MakaraPostgreSQLAdapter underneath which
should be found and used automatically, perhaps:
class MakaraPostgreSQLAdapter < PostgreSQLAdapter; end
This would inherit the main PostgreSQLAdapter functionality. If it
works, please do send it into the scoped_search project.
> default is an integer -- 0 -- instead of a boolean -- false, which
> causes PostgreSQL to throw a PGError.
> should be generated
> the adapter. It seems like there's something in the chain of execution
> that isn't recognizing the Makara adapter as a valid PostgreSQL adapter,
> but I'm just not seeing where
For anyone who's interested, I solved the issue by creating a Rails
initializer @ /usr/share/foreman/config/initializers/makara.rb with the
following monkey patch:
require 'scoped_search'
class ScopedSearch::QueryBuilder
end
On Thursday, March 10, 2016 at 9:36:41 AM UTC-5, Jon McKenzie wrote:
> Actually, I think I just found the issue. In scoped_search, the particular
> query builder chosen is based on the class of the underlying DB connection:
> https://github.com/wvanbergen/scoped_search/blob/master/lib/scoped_search/query_builder.rb#L30
> In my case, this method resolves to MakaraPostgreSQLAdapter not
> PostgreSQLAdapter, so scoped_search choses the default query builder.
> I submitted a bug to ``scoped_search`` here:
> https://github.com/wvanbergen/scoped_search/issues/139
> ..I suppose I will need to either directly patch this to get it working or
>> reads to a DB read replica? (Or can recommend some other approach?)
>> translates to:
>> should be generated (
