Greetings!
Thank you so much for your help & apologies for the delayed revert!
If the katello-agent
is deprecated, I think I would rather stick to the remote execution
. I shall study the nightly doc which you have referred & let you know if I have any queries.
Aside, one query I have as you mention earlier, subscription-manager
must be already installed on a client to get registered with Foreman. I checked and found out that if the base
OS is installed, subscription-manager
is not available on the system & to have the prerequisite in place, I have to grant internet access to client first to have it installed and then initiate a Foreman registration process.
Is there any way where I can download/install the subscription-manager
package from the foreman itself? (using wget
or something) If that is possible, then I do not need to connect to the internet.
Regards,
