When i use command:
pulpcore-manager migrate --noinput
System check identified some issues:
WARNINGS:
?: (guardian.W001) Guardian authentication backend is not hooked. You can add this in settings as eg: `AUTHENTICATION_BACKENDS = ('django.contrib.auth.backends.ModelBackend', 'guardian.backends.ObjectPermissionBackend')`.
Operations to perform:
Apply all migrations: admin, auth, certguard, container, contenttypes, core, deb, file, guardian, pulp_2to3_migration, rpm, sessions
Running migrations:
Applying core.0049_add_file_field_to_uploadchunk...Traceback (most recent call last):
File "/usr/lib/python3.6/site-packages/django/db/backends/utils.py", line 84, in _execute
return self.cursor.execute(sql, params)
psycopg2.errors.NotNullViolation: column "file" contains null values
The above exception was the direct cause of the following exception:
File "/bin/pulpcore-manager", line 11, in <module>
load_entry_point('pulpcore==3.9.1', 'console_scripts', 'pulpcore-manager')()
File "/usr/lib/python3.6/site-packages/pulpcore/app/manage.py", line 11, in manage
execute_from_command_line(sys.argv)
File "/usr/lib/python3.6/site-packages/django/core/management/__init__.py", line 381, in execute_from_command_line
utility.execute()
File "/usr/lib/python3.6/site-packages/django/core/management/__init__.py", line 375, in execute
self.fetch_command(subcommand).run_from_argv(self.argv)
File "/usr/lib/python3.6/site-packages/django/core/management/base.py", line 323, in run_from_argv
self.execute(*args, **cmd_options)
File "/usr/lib/python3.6/site-packages/django/core/management/base.py", line 364, in execute
output = self.handle(*args, **options)
File "/usr/lib/python3.6/site-packages/django/core/management/base.py", line 83, in wrapped
res = handle_func(*args, **kwargs)
File "/usr/lib/python3.6/site-packages/django/core/management/commands/migrate.py", line 234, in handle
fake_initial=fake_initial,
File "/usr/lib/python3.6/site-packages/django/db/migrations/executor.py", line 117, in migrate
state = self._migrate_all_forwards(state, plan, full_plan, fake=fake, fake_initial=fake_initial)
File "/usr/lib/python3.6/site-packages/django/db/migrations/executor.py", line 147, in _migrate_all_forwards
state = self.apply_migration(state, migration, fake=fake, fake_initial=fake_initial)
File "/usr/lib/python3.6/site-packages/django/db/migrations/executor.py", line 245, in apply_migration
state = migration.apply(state, schema_editor)
File "/usr/lib/python3.6/site-packages/django/db/migrations/migration.py", line 124, in apply
operation.database_forwards(self.app_label, schema_editor, old_state, project_state)
File "/usr/lib/python3.6/site-packages/django/db/migrations/operations/fields.py", line 112, in database_forwards
field,
File "/usr/lib/python3.6/site-packages/django/db/backends/base/schema.py", line 447, in add_field
self.execute(sql, params)
File "/usr/lib/python3.6/site-packages/django/db/backends/base/schema.py", line 137, in execute
File "/usr/lib/python3.6/site-packages/django/db/backends/utils.py", line 67, in execute
return self._execute_with_wrappers(sql, params, many=False, executor=self._execute)
File "/usr/lib/python3.6/site-packages/django/db/backends/utils.py", line 76, in _execute_with_wrappers
return executor(sql, params, many, context)
File "/usr/lib/python3.6/site-packages/django/db/utils.py", line 89, in __exit__
raise dj_exc_value.with_traceback(traceback) from exc_value
django.db.utils.IntegrityError: column "file" contains null values
I did full migration to pulp3 from 2 and use : foreman-maintain content remove-pulp2, but script try to use all steps migration with pulp_2to3_migration ???
Maybe is it problem ?
