I had some time to start on integrating Foreman (the smart proxy for now)
and Icinga2 but now I have no idea when I find some more time but perhaps
someone else wants to have a first look into or take it to the next level.
Idea was to route the communication through the smart proxy, so I started
with this. In Icinga2 we have a rule based configuration so only creation
of a host with custom attributes is required then services, notifications,
dependencies and so on will be added automatically depending on the rules.
Status is this:
If the smart proxy gets a post request it creates the host on Icinga 2 or
updates it if already existing. I did not add the zones attribute for now
required in a cluster setup and hit some bugs in the Icinga2 api in
creating endpoint and zone required for running Icinga2 also as agent. Also
for now Icinga2 does not re-evaluate apply rules on changes.
If the smart proxy gets a delete request it will delete the host and all
depending objects. Endpoints and zones should also work but is not tested
without being able to create them.
If the smart proxy gets a get request it will print some status
information. This is only for testing. Later it should get the initial
state for all hosts and services on start up and then connect to an event
stream to get updates on state changes, downtimes and acknowlegements and
forward it to Foreman.
Hope all is well - I am attempting to get Icinga2 and Icinga2 Web Interface
up and running on Ubuntu 16.04 OS.
I've gotten all the packages pulled down, it appears everything has
installed correctly however I'm running into a small issue getting the GUI
up and running:
When I attempt to go to the http://localhost/icingaweb2/setup page I'm
getting a message that You don't have permission to access http://IP
address/icingaweb2/setup on this server.
Any thoughts on the steps I might of missed or need to still do for the
setup - I'm trying to roll this out by Wed. morning so I can compare this
product and the legacy Nagios product as this looks a whole lot easier to
manage.
Thanks for your help and time at looking at this - much appreciated.
Best regards,
Ryan
On Tuesday, April 5, 2016 at 1:29:35 PM UTC-4, Dirk Götz wrote:
Hi all,
Status is this:
or updates it if already existing. I did not add the zones attribute for
now required in a cluster setup and hit some bugs in the Icinga2 api in
