Wondering if anyone has written a nagios or icinga puppet module that
uses native Foreman data rather than storeconfigs to populate the
nagios configs?
(Guessing not, since Google is coming back with basically nothing).
Brian
Not quite what you are looking for but there is that :
https://github.com/favoretti/puppetdb-external-naginator
It uses puppetdb as storeconfigs but don't use buggy naginator to collect
data and write nagios configuration.
Regards,
Romain
2013/10/29 Brian Gupta
nagios configs?
Brian
“Foreman users” group.
I need this too but finding nothing. I really don't want to go back to
PuppetDB…
> nagios configs?
> Thanks,
> Brian
I guess I wasn't clear. Basically I am looking for a module that can
build nagios/icinga configs, without using Puppet "exported
resources". (I am trying to see if I can do this without storeconfigs
or puppetdb).
(I already have it working using "exported resources" but want to see
if it's possible to do this with just Foreman native data. I am
already exporting all facts directly into Foreman.)
Brian
On Tue, Oct 29, 2013 at 4:54 AM, Romain Vrignaud wrote:
> Hello,
> Regards,
> Romain
>> nagios configs?
>> Thanks,
>> Brian
>> "Foreman users" group.
>> email to foreman-users+unsubscribe@googlegroups.com.
>> To post to this group, send email to foreman-users@googlegroups.com.
>> Visit this group at http://groups.google.com/group/foreman-users.
Unfortunately nothing has come up since, so we just basically brought
a leaf PuppetDB node into our environment just to support this one use
case.
It's frustrating but I think that's the only option that
doesn't involve a huge amount of work.
-Brian
> PuppetDB....
>> nagios configs?
>> Thanks,
>> Brian
Hey Brian,
Yes, it's totally doable but it's not nearly as easy to say the least.
We have monitoring with a Nagios puppet module built using the Foreman API
to discover hosts, classes, parameters, etc. It's very specific to our
use-cases though, and not something generic that the world could benefit
from. But we essentially loop through every host discovered from the
Foreman API and have a bunch of if statements to determine which classes
are assigned to each host, and if there are any parameters associated with
those classes that determine how we should monitor the service.
We actually use the Puppet Future Parser and our manifest works like so
(bits and pieces):
class nagios {
each($foreman_api::servers) |$key, $value| {
$host_name = $value['host']['name']
$myclasses = $foreman_api::hostLevelClasses[$host_name]
# PostgreSQL
if ($myclasses['postgres']) {
$checkPostgres = true
.. some params related to PostgreSQL
.. etc
And then we have a template file that generates the nagios checks per host.
Pro's are that you don't need to rely on exported resources, naginator, or
any of that stuff. Con's are it takes awhile to generate the catalog for
the Nagios host (about 5 mins for 500 servers or so, on a moderated sized
VM) and it's very specific to your monitoring.
Jason
> case. :( It's frustrating but I think that's the only option that
> -Brian
> > PuppetDB....
> >> nagios configs?
> >> Thanks,
> >> Brian
> Groups
> an
> > email to foreman-user...@googlegroups.com .
> > To post to this group, send email to forema...@googlegroups.com
