I am using the puppetssh provider to enable the puppet run in foreman.
While running the puppet run from foreman console I am getting below error:
failed to execute puppetrun: ERF12-4252 [ProxyAPI::ProxyException]: Unable
to execute Puppet run ([RestClient::ResourceNotFound]: 404 Resource Not
Found) for proxy https://<hostname>:8443/puppet
Can someone please help me with this error?
I have followed all the steps mentioned in foreman manual for puppetssh.
JFYI I am using foreman 1.10 version.
On Wednesday, June 8, 2016 at 11:49:54 PM UTC+5:30, Sanjiv wrote:
> Hi,
> Found) for proxy https://:8443/puppet
> Thanks,
> Sanjiv
What permissions does the file have? It should be read-able to the
foreman-proxy user, e.g. 0644 or 0640 with group set to foreman-proxy.
On 08/06/16 19:50, Sanjiv wrote:
> Also I can see error in proxy.log as
> [2016-06-08T23:51:23.184500 #25111] ERROR -- : Couldn't enable plugin
> puppet: Permission denied - /etc/foreman-proxy/settings.d/puppet.yml
